Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-25-2009, 11:45 AM
65fordguy's Avatar
65fordguy 65fordguy is offline
65fordguy is starting off with a positive reputation.
Buying an 04 > clunk after engages 4 hi >normal?
I own a 2001 supercrew lariat.... when I put it into 4 hi or lo.. its a smooth transition... I have driven several of the newer model trucks and each one of them have a clunk or clank after it engages. The process of engaging is solid and smooth... but a few seconds afterwards there is the noise... is this the lockers locking and im just not used to it? After all all of them have done it... or all of them flawed?
All have been 04 model years.
Thanks for helping.
  #2 (permalink)
Old 10-25-2009, 03:03 PM
tylus's Avatar
tylus tylus is offline
Navy Nuclear Mach. Mate
2008 Ford Expedition
tylus has a good reputation on FTE. tylus has a good reputation on FTE.
it's normal for some slight noise
there are alot of metal components that have to get spun up to speed and rotate.
a continual noise is not good. but just that initial noise is just fine.
for those 04 models, are they the new body style or the old body style (like your 01)? because there are some pretty extreme differences between the 2 bodystyles in 2004.
__________________
2008 Expedition EL - Hers....Bone Stock
2009 Mustang Bullitt - Mine..F'ing quick
Currently deployed. See y'all on the flip-side.
  #3 (permalink)
Old 10-25-2009, 04:05 PM
tbear853's Avatar
tbear853 tbear853 is offline
tbear853 is starting off with a positive reputation.
You have the transfer case in which the forward drive shaft's output is engaged, then you have two actuators that engage the front lockers which lock the front axles to the wheels. The three points are all machanically locked once engaged. There are no smooth clutches doing te locking.
Some momentary noise as splines / dogs line up and find their places together is normal.
Also why you don't run 4wd on non slick surfaces, and why you back up to release as these components get "wound up" against each other due to slight differences in front to rear loading, air pressure, and travel through corners.
  #4 (permalink)
Old 10-25-2009, 06:16 PM
65fordguy's Avatar
It's the new style... What are the differences
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
