Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
General Diesel Discussion SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-25-2009, 07:11 AM
rustyoldford's Avatar
rustyoldford rustyoldford is offline
rustyoldford is starting off with a positive reputation.
atf/diesel mix
Because I trust the folks at this site more then at the dodge sprinter site, I'd thought I'd seek your opinion on this comment. I've a buddy with a transmission shop, and could probably get all I want. Not sure how I"d filter it to 3 microns or if the diesel from BP, Shell, , , , is even that clean
"I am currently running filtered waste ATF through my sprinter. I have been doing this for some time and am very pleased with performance. I filter to 3 micron before running through my truck. My current bargain mix is 85% ATF and 15% RUG (Unleaded Gasoline). My only issue currently is a bit more smoke from unburned fuel. I believe due to the higher BTU content of the ATF vs. Diesel that the mixture is too rich.
there is a lot less carbon in ATF than engine oil. viscosity is also still decent at colder temps. Working with a couple of other engineers on a filter to remove carbon from waste engine oil. We have been doing this for over a year in a VW Golf and my Sprinter. Runs quieter and gets slightly better mileage. Only downside thus far is changing fuel filters every 5k miles.
On a 50/50 mix of ATF and diesel the truck does not smoke at all."
__________________
"never threaten anyone- - - - it ruins the surprise"
97 merc
05 sprinter diesel
  #2 (permalink)
Old 10-30-2009, 10:44 PM
cheezit cheezit is offline
cheezit is gaining momentum as a positive member of FTE.
Im not sure what the need for RUG is in any mix to go in to a diesel. Maybe you could fill me in on that sounds interesting.
There is more then one person running around 7.3L powerstrokes on 100% atf with no smoke at all. ATF burns well in that engine from all the post I have read.
There was some talk of that the 6.0l powerstroke as well but no reports back from people how have tried it.
  #3 (permalink)
Old 10-31-2009, 09:33 AM
Hmmmm
We need a report from some of the people burning it. I'm certain I'd need to come up with a way to filter waste atf before I put it in my tank also. And I'm not coming up with any ideas at the moment.
Let me think, a 55galon tank, and electric pump pushing thru a 5 micron filter, dumping into my van everytime I have a half tank of diesel.
Lets wait till some atf burners chime in
__________________
97 merc
05 sprinter diesel
  #4 (permalink)
Old 10-31-2009, 02:45 PM
HT32BSX115's Avatar
HT32BSX115 HT32BSX115 is offline
HT32BSX115 is starting off with a positive reputation.
Howdy,
Running used ATF (or new for that matter) is right up there with running used engine oil and WVO.
I wouldn't do it. Hydraulic oils have additives that were never intended to be burned in any combustion chamber (except that I run it mixed with a whole bunch of other oils in the waste oil furnace in my shop!!)
Now, having said that below is an article that speaks directly to running (successfully) it in various engines.
Automatic Transmission Fluid Fuel - Alternative Diesel Fuel - Diesel Power Magazine
Just don't get stopped by the "fuel cops" ...... since it's red, they'll be after you to prove that you paid federal and state road tax on it and if you can't, the fines are extensive!!
While the number of "carbons in the chain" in ATF is a it longer, the BTU content is not that much higher as to be significant.
#2D has a BTU content of about 135,000-138,000 btu /gal
Crude oil is around 140,000 per gallon. ATF is going to be in the middle somewhere. The difference is negligable.
Dince diesels run with an excess of air, they're ALWAYS running lean.
You know when they're "rich" (over-fueled) from the black smoke coming from the smoke pipe. (rich vs lean is not a valid argument with diesels anyway because of the excess of air available for combustion)
Regards,
Rick
__________________
1955 F-600 // D I S C L A I M E R: No animals were injured while test driving my F-600 except the ones I RAN OVER INTENTIONALLY!!! (RESISTANCE IS FUTILE) 73 de Rick
  #5 (permalink)
Old 10-31-2009, 05:59 PM
as Ive stated there lot of 7.3l guys running on atf at 100%. I dont know of anyone doing it on a 6.0l.
should you run it? thats up to you. Proving its had taxes paid is not hard to do. a lab test will prove that. I just dont know that once you do prove it tthat the epa will like you.
the reason you are smoking is simple its the regular gas in your mix. the sub of diesel proves that. I have seen more then enugh people pump gas in there diesels and the ones that run smoke like mad.
To filter is easy. find a pump from a 7.3l psd wich is a frame mounted pump with one inlet and one outlet. hook a filter to the suction side of the pump and pull it through a 2-3 micron filter, after wich I would pump it in to what ever you need it in. The reason I suggest a 2-3 micron filter is that is the standard on the inline filters and that should help filter life.
Once again Im also in agreement with the btu being somewhat close that it should not matter. I would worry a little bit about excessive carbon build up if you engine has an egr system.
  #6 (permalink)
Old 11-01-2009, 07:39 AM
carbon build up on egr!
yes would be a problem, seems to be a regular problem at the sprinter site, and egr's reported to be about $500 each, not sure what a ford egr runs. When the egr on my 1985 460 rotted thru I just replaced it with an aluminum spacer. I think the newer engines monitor to many things to do that. At the sprinter site I believe I read a faulty glow plug causes "limp home mode" and thats ridiculous to me
Now if we can just get ford to sell the big transit here in the states(not that submini transit connect) I'd at least know what to buy next time.
Better yet make it here, an import is an import. And if an american is not working there is no reason to give the big shots a bonus
__________________
97 merc
05 sprinter diesel
  #7 (permalink)
Old 11-01-2009, 07:49 AM
that link says no to atf in common rail systems, sprinters are common rail. Not sure what the problem would be myself but at the current time I think I'll avoid it
__________________
97 merc
05 sprinter diesel
Tags
73 , atf , auto , automatic , diesel , filter , fluid , ford , fuel , micron , mixed , mixing , powerstrokes , rich , running , transmission , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
