2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2009 Expedition EL Brake Booster noise
Old 10-25-2009, 03:37 AM
Biscayne's Avatar
Biscayne
Biscayne is offline
Here is the deal. After braking (soft or hard) when I release the brake pedal then accelerate, you can hear the brake booster diaphragm "pop" back to neutral. After releasing the brake, the brake pedal returns instantly to the standby (non-depressed position) but the booster goes on a few seconds later to sound like a damper door shutting. I took it in and the techs (along with help from the engineer help line) diagnosed it as a harmless sound that is a by-product of the design. They said they tested another '09 on the lot (new) and it did the same thing. If it did it everytime, I might buy it, but it is intermittent. Anyone else out there had something similar? I am at a dead end (at least with this dealership)
Old 10-26-2009, 04:23 PM
tvl's Avatar
tvl
tvl is offline
Hello Biscayne!
I do believe I have experienced the same noise you are experiencing and it does sound very similar to a damper noise as you described, but it can be loud at times. I have learned how to avoid the issue by altering my driving habits and only rarely hear it because of the change.
Please read more here (a thread I started some time back): 2008 Expedition Acceleration Noise - Ford Forums - Mustang Forum, Ford Trucks and Cars
Please let me know if you get a resolution on the issue. Our dealership never had a clue as to what was happening.
TVL
Old 10-26-2009, 06:55 PM
berry1234's Avatar
berry1234
berry1234 is offline
"Yes, I was having the exact same problem as you were. Called a friend who a mechanic. He explained to me that the only thing probably happening was the lack of, or too much "air" in the vacuum braking system. He instructed me to turn off the vehicle, pump the brakes until it won't pump any more (about 3 or 4 pumps), and that should eliminate the air, or gaps in the vacuum system. It actually worked. Once I did that, it didn't matter what I did acceleration wise, or how long the truck sat, the noise was gone!!! That seemed to have worked for me. He said only if it is consistent will it actually be the brake power booster, meaning every time you accelerate from braking, not just once after sitting. If it was occassionally, or after sitting, it meant that the there was a lack of, or too much air in the vacuum braking system. He said it commonly happens with temperature/pressure changes, outside, similar to what can happen with tire pressure. He said that the people who got theirs replaced thinking it was the problem, the technician would have "pumped" or bled the brakes anyway eliminating the problem after an unnecessary part change."
Sounds like some good info.
86pullerf350
06-15-2016 09:34 AM
jasonmesq
01-17-2016 11:48 PM
cmongft
Large Truck
10-19-2014 08:48 PM
GuitarJesus
03-25-2014 09:31 PM
fwerring
1997-2006 Expedition & Navigator
08-31-2010 03:52 PM
Quick Reply: 2009 Expedition EL Brake Booster noise
