Expecting rain on thursday, can I pour concrete on Monday? - Ford Truck Enthusiasts Forums
Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Old 10-25-2009, 03:12 AM
karljay karljay is offline
karljay is starting off with a positive reputation.
I'd like to pour a foundation as an addon to the house, about 100 sq ft. It would be done Monday midday, rain is expected thurs or friday. Should I wait or get some plastic and cover it or what?
I don't want to use any quick-cure stuff as I understand they can weaken the pour.
Thanks, KarlJay
Forgot to add, this is Sacramento and the outlook is upper 70's. The area to be poured is not in direct sunlight. 16~18" footer and 4" inner.
Old 10-25-2009, 05:58 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
it will only need 24 hours to become weather tight.
unless you are talking about freezing cold, which i don't think you need to worry about.
Old 10-25-2009, 08:33 AM
LMS Residential's Avatar
LMS Residential LMS Residential is offline
LMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputation
Pour away brother. The rain on Thursday will only serve to wet the cured concrete which is actually beneficial.
Used to live in Sacto on Robertson, our biggest problem pouring there was trying to slow the cure in the dry summer heat.
Old 10-25-2009, 12:51 PM
dstig1 dstig1 is offline
dstig1 is gaining momentum as a positive member of FTE.
The 2 biggest weather concerns with pouring concrete are freezing temps before it is cured, and hot dry weather that dries out the water before it has a chance to cure (concrete cures by hydration, not evaporation - the water becomes part of the concrete so if it dries out you get weak concrete). Rain during a pour is an issue if it is heavy, but not a day or more later. Heck, even rain a couple hours after finishing wouldn't be an issue if you cover it with plastic.
Old 10-25-2009, 11:33 PM
Nitramjr's Avatar
Nitramjr Nitramjr is offline
Nitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant future
I'd go so far as to water the surface of the concrete on Tuesday and Wednesday and not wait until Thursday for it to get rained on. As was mentioned, concrete likes having the water present - it will cure harder than it would in dry conditions.I'd wet it down every day for a week.
Old 10-26-2009, 09:35 AM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Just don't water it too soon, or you'll wash the slip off.
need argon tank for new tig, what size and how much $ karljay Garage & Workshop 11 01-31-2006 11:16 PM
Mods to 460 for towing and MPG karljay Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 7 11-22-2004 04:54 PM
240 I6 conversion to 300 I6 karljay Ford Inline Six, 200, 250, 4.9L / 300 15 11-21-2004 11:03 AM
Oiling mods to 460 are they needed? karljay Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 11-19-2004 06:33 PM
c6 fluid capacity karljay Clutch, Transmission, Differential, Axle & Transfer Case 2 03-20-2001 11:51 AM
Tags
cold, concrete, cover, curing, day, expecting, footers, heavy, plastic, pour, pouring, rain, raincalifornia, rains, times
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
