lift kit
NO Blocks In the front!!!!! One helper spring in the front with new ubolts should get ya up and runnin! In the front you can go 2 inches but depending if you wheels are sagging you will have to install camber bushings. With the plow on it may level things out. Rear you can put a 2 inch block back there, but axil wrap is going to increase. We have the same problem with our 96 f-250 with the plow she saggs REALLY bad just needs a helper in the front its on the to do list too!!
Two inches should not need longer shocks or steering pitman arm drop.. anything more than 2" might require shocks and drop pitman.
Last edited by donniezyea; 10-24-2009 at 10:22 PM. Reason: forgot about his shock and steering arm question
