Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-24-2009, 06:19 PM
caughtbasslately caughtbasslately is offline
caughtbasslately is starting off with a positive reputation.
Heater / AC Blend Door Actuator (clicking)
what is the difference between part # XF2H-19E616-FA
and part # YL5Z-19E616-AA? the middle numbers are the same.
and they look the same? the first one is mine. Blend door actuator out of a 2000 ford windstar. Will another part # work?
if the connection is the same?
Thanks for your help.
  #2 (permalink)
Old 10-24-2009, 07:33 PM
I can't see a differance.
  #3 (permalink)
Old 10-24-2009, 09:45 PM
anybody?
  #4 (permalink)
Old 10-24-2009, 10:21 PM
somebody any body
Thanks
  #5 (permalink)
Old 10-24-2009, 11:58 PM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
1998 Ford F-250
Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of
Hold on a second. Nice to have you here but you must realize that people with Windstar part numbers are not just waiting around. Give your question a little time.
__________________
Dan
1998 F250 LD 4X4
Forum Guidelines
See you in the Kansas Chapter
  #6 (permalink)
Old 10-25-2009, 08:59 AM
Hello, I was glad to fine this web site.
I don't think there's a difference.
mine came out of a windstar but there in most fords.
Then I noticed only the first 4 and last 2 letters were different.
I looked at allot of them for allot of fords on ebay. some have a different connection but allot of them look identical.
19E616 is the same on them I thinking they will work and I can just buy the cheapest one.
Thank you for your reply, sorry for being so jumpy.
Thanks again for the welcome.
  #7 (permalink)
Old 11-19-2009, 10:17 PM
HomerWinzlow's Avatar
HomerWinzlow HomerWinzlow is offline
HomerWinzlow is gaining momentum as a positive member of FTE.
Its best to spend the few dollars more to get the correct one. Some are EATC controlled, some Semi EATC, some Manual. Every blend door has a different length of throw from full open to full closed and therefore would show different resistance values for each increment of position. Some of the leads are for door position feedback so one actuator indicating half open may have the same resistance as one at full open. There is a reason for those numbers and for keeping the correct part with the correct application. The middle set of numbers is simply a base number for all electronic actuators of that type. They can be blend door, fresh air door, floor door, or other mode control door actuators and have the same base part number. Some actuators have different shaped shafts on them too. Some are entirely different like on the late models but still have the 19E616 base part number.
It can be very easy to have the wrong part.
__________________
My advice is just advice..Its free "IF THAT DONT FIX IT, SOMETHING ELSE WILL"
IF IT AINT BROKE DONT FIX IT!!
My Missing Michelle
Tags
2000 , 2008 , ac , actuator , airconditioner , blend , clicking , door , f150 , f250 , ford , heat , heater , windstar , xf2h19e616fa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
