I have a cheap after market single din in there with my JL audios hooked up in the front doors, and some cheap 6x8 in the back doors.
Time to:
*Replace the radio with a eclipse AVN 5500 that i got for free!
*Amp the 2 JL up front, leave the 2 back running off the head unit.
*install the back up cam for the 5500.
*Install the Sirus sat box
* maybe install a xbox
* bypass the dvd
*install handsfree stuff
*big 3 upgrade for the batteries
ANY advice on taking the carpet up or just the sides? and adive for taking the dash apart?
__________________
Ehsan **I make sure drivers know they messed up on the road**
1999 Forest Green F-250 XLT
7.3L Diesel| Banks Power exhaust | K&N Filter | 12 inch lift | 42 inch Super Swampers |
__________________
Not sure of your cab configuration but pulling the seats/carpet is extremely easy in the F250's. I pulled all mine up when I added my amp/sub. I have the ext. cab, it was 4 bolts each (actually 2 nuts/2 bolts) for the driver/pass. seats and I believe 4 bolts for the center console/seat. Once those are out of the way, you can see what smaller pieces of trim need to come up.
The dash just pulls straight out, grab a corner and pull (careful though, not too far or you'll pull apart your dash connections). I was able to install my nav/dvd unit without pulling the dash completely out.
__________________
2000 F250 V10, sc, lb, 6.5in Pro Comp lift, Bilstein 5100's, 37in Toyo M/T's, 17in MT Classic II's, K&N FIPK, 3.5in B&B exhaust, Randy Ellis light bar, 4 - 8in KC 800 Series lights
thanks for the reply..how bout the carpet itself...easy to take out and put back in?
where did u put ur subs? i also have the extended cab
__________________
do u hafe crew cab or extended..i really dont see a place for a sub in the xtended cab
__________________
dont really like pre fabs.. i will have to figure some thing out
__________________
