Help! Need Wiper Switch!!!!!
Old 09-10-2010, 11:03 PM
65_Guy's Avatar
65_Guy
65_Guy is offline
Just confirming. The OE switch (single speed, 5 pole) for a '65 F100 is C3TZ17A553G. Can anyone confirm this? If it is, I'm screwed. No one has any. Or do they?
Edit: Just saw F250GH's post. So you used C3UB-17A553-C1 in place of C3TZ17A553G and it worked?
Old 09-11-2010, 04:00 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by F250GH
I just removed from my 1965 F250 single speed wiper, switch #C3TB-17A553-G1 (C3TZ17A553G). I ordered the replacement you spoke of from Green Sales #C3UB-17A553-C1 (C3UZ17A553C) and it is identical.
Just installed and works perfectly. However it was expensive, ($75).
65_Guy: See post #4 for additional information inre to C3UZ17A553C being a replacement for C3TZ17A553G.
Ford ID number marked on switch: C3UB-17A553-C1 = Ford part number: C3UZ17A553C
Edit: 1/30/2011 =
There are other sources besides Green Sales who has FIVE = 800-543-4959.
NOS PARTS SOURCE in Lenexa KS has ONE = 913-220-5746.
JST AUTOMOTIVE in Lebanon TN has ONE = 615-443-3086.
WESLEY OBSOLETE PARTS in Liberty KY has TWO = 606-787-5293.
Old 01-28-2011, 08:02 PM
rsequipmentsales's Avatar
rsequipmentsales
rsequipmentsales is offline
I am in need of a single speed wiper switch for a 1965 for f-100 part #c3tz-17a553g, please let me know if you can help, Thanks!
Old 01-28-2011, 10:53 PM
69supercj's Avatar
69supercj
69supercj is offline
I've probably got a used one, 20 bucks plus the ride.
Old 01-29-2011, 11:12 PM
rsequipmentsales
65- Ford F-100 wiper switch
Thanks for your quick responce for the switch. Please let me know how I can pay you. Thanks, Randy.
Old 01-30-2011, 06:58 PM
69supercj's Avatar
69supercj
Give me a few days to get it dug out. We're expecting ice and snow here starting tomorrow so I might get delayed. If you find one sooner, no problem on this end.
Old 02-04-2011, 04:25 PM
rsequipmentsales
have you found the wiper switch that i need? 65 ford F-100 single speed. Thanks,
Randy. 530-626-5894.
Old 09-03-2014, 08:29 PM
safetysteve's Avatar
safetysteve
safetysteve is offline
Bill I am new to this forum, obviously you are the man. I have a 65 f100 # 651--- If I read correctly it should have a one speed witch? Currently the wipers are not working and the switch is a two speed. Also, should there be a washer (electric ) ? Thank you very much for all the great info on this forum.
Old 09-04-2014, 06:50 PM
NumberDummy
Originally Posted by safetysteve
Bill I am new to this forum, I have a 65 F100 --- If I read correctly it should have a one speed switch?
Currently the wipers are not working and the switch is a two speed. Also, should there be a washer (electric) switch?
Both single and two speed wipers were available for these trucks, the two speed wipers were optional.
C3TZ-17A553-E .. TWO Speed Windshield Wiper Switch-4 terminals / Marked: C3TB-17A553-A or C3TB-17A553-E / Obsolete
1963/65 F100/950 / 1966 F100/950 before serial number 760,001 / 1963/66 Econoline.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
MCDONALD OBSOLETE PARTS CO. in Rockport IN has 1 = 812-359-4965.
MILLER OBSOLETE PARTS in Binghamton NY has 2 = 607-722-5371.
Windshield washers were an option, so not all these trucks have it.
On a 1965 and some 1966's, the push button washer switch (if so equipped) is located above the ignition switch. It's also the same as the starter switch for all 1952 Ford trucks.
2C-11500-A .. Washer Switch (Motorcraft SW-287) / Obsolete
1965 F100/250 with single & two speed wipers / 1966 F100/250 with single speed wipers / 1966 F100/250 with two speed wipers before serial number 760,001 / 1966 Econoline.
GRIESEL MOTOR CO. in Okarche OK has 2 = 405-263-7242.
WESLEY OBSOLETE PARTS in Liberty KY has 3 = 606-787-5293.
NOS PARTS LTD in Waxahachie TX has 4 = 972-937-2201.
OBSOLETE RELIABLE PARTS in Nashville GA has 4 = 229-686-5101.
Old 08-19-2016, 04:22 PM
FordExplrer's Avatar
FordExplrer
FordExplrer is offline
Reviving this thread because after reading many posts about the one speed wiper switch, and the fact that no one NOW is selling it, what are the options. I was trying into looking into two speed switches and just splicing in spade connectors to the back of the switch but I am not sure if this will work. I am going to attempt to rebuild the switch but failed twice already.
Does anyone know of other ways to not have to buy a two speed motor and setup just because the C3UZ-17A553-G switch is obselete now? I even tried calling around for the Econoline switch and its gone too.
Similar years of the Fairlane, Falcon, Econoline and Galaxie all yeilded the same results, nothing for the one speed switch.
Old 08-19-2016, 05:39 PM
6t6merc's Avatar
6t6merc
6t6merc is offline
I swapped a single-speed system holus bolus for a two speed. It cost about $30. Then for $75 more I added the intermittent feature which I believe you cannot do with a single-speed.
Old 08-19-2016, 05:45 PM
NumberDummy
Originally Posted by FordExplrer
Does anyone know of other ways to not have to buy a two speed motor and setup just because the C3UZ-17A553-G switch is obsolete now?
C3UZ-17A553-G is an invalid part number.
C3UZ-17A553-C is a single speed wiper switch with 5 terminals for a 1963/66 Econoline / Obsolete ~ 1 available NOS
C3UZ-17A553-D is a single speed wiper switch with 3 terminals for a 1963/64 F100/600 & 1963/66 Econoline / Obsolete ~ 27 available NOS
C3TZ-17A553-G is a single speed wiper switch with 5 terminals for a 1963/66 F100/600 / Obsolete ~ 0 available NOS
  #28
Old 08-22-2016, 09:28 AM
FordExplrer
Thanks Numberdummy, I have seen all these switches but none will be a direct plug and play fit, so some splicing of spade connectors will need to get done, my only hesitation in buying one of them is that there are fewer wire connections. You have that there is one C3UZ-17A553-C at NOS but when I look it up is says out of stock.
I am willing to take any switch that will work properly and splice the wires into it, but at around 40 bucks a pop I dont want to have to keep buying switches to figure out which will work, I am not the best at electrics so its one of these or a universal switch like this one which is pretty ugly.
Universal Windshield Wiper Switch for Single Motor (is a two speed but only kind of universal I have found for a single wiper motor)
Mine is a 5 terminal one speed no washer switch, four for the switch and one located at the bottom for power.
Will a three terminal C3UZ-17A553-D work just as fine as long as the correct wires are hooked up? Will the wiper park feature still work correctly?
  #29
Old 08-22-2016, 09:35 AM
TA455HO's Avatar
TA455HO
TA455HO is offline
Here's that one NOS switch that it says is in stock.
C3UZ-17A553-C | RearCounter.com | 1 found at 1 seller
Call the Mustang Service Center and see what they can do for you.
But, if it were me I'd switch (no pun intended) to a two speed wiper motor if you don't have one already and just get the newer intermittent wiper switch and governor and make an improvement out of the project. It is a clean and simple install to do. Lots of donor vehicles out in the world to get the parts from. The newer switch also activates the electric washer pump motor so you don't have to have a separate switch for that.
  #30
Old 08-22-2016, 09:57 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Have you opened the original switch to take a peak at the failure mode of that thing? Naturally replacement is a lot easier than repair but in this situation when the part is now unobtanium it's worth looking at. It's not a high tech component. ON and OFF, right? I bet you could cannibalize the innards from something else if needed.
Quick Reply: Help! Need Wiper Switch!!!!!
