Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V10 (6.8l)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Modular V10 (6.8l) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-24-2009, 01:36 PM
390unibody 390unibody is offline
390unibody is starting off with a positive reputation.
V10 showing hot
I have a 03 v10 that the heat guage keeps showing hot and then goes in safe mode.Never know when it is going to do it and cannot find a reason. Put a new thermostat first no luck. Then temp sensor, again no luck. Just swaped the ecu and still doing it. I have a temp gun and when it goes into safe mode the head temp is around 170. Turn the key off and back on and the temp is normal and out of safe mode. May run a week or may run 2 minutes until it does it again. If its a wiring problem why does turning the key off reset it? Any ideas? Thanks
  #2 (permalink)
Old 10-24-2009, 02:02 PM
boxcar1974's Avatar
boxcar1974 boxcar1974 is offline
boxcar1974 is gaining momentum as a positive member of FTE. boxcar1974 is gaining momentum as a positive member of FTE.
Check the clutch fan. This will cause an ingine to run hot. I just went though this last winter. The temp would rise to 270 and stay and climb a bit. I would pull over and shut it off and wait for it to cool down. Sometimes upon restarting the temp was back to normal and sometimes it stayed high. It would no this with no indication. It would go a couple weeks and be fine then boom,,,,270 degrees. I did the same as you and eventually took it to a mechanic and found the clutch fan was not operating correctly all the time. Changed the clutch fan and perfect.
Just a place to look.
Good luck.
__________________
03' F-250, XLT Sport, V10, Banks Powerpack, SVT 18x8 wheels, and Toyo Open Country A/T 285-65-18E
09' F-350, XLT, V10, Regular Cab
Michael
  #3 (permalink)
Old 10-24-2009, 02:51 PM
Thanks for the reply but when my truck is showing hot the engine and head temp is between 160-170 degrees when i check it with a temp gun.
  #4 (permalink)
Old 10-24-2009, 03:02 PM
boxcar1974's Avatar
I understand, this happened to my work silverado. While the guage read 270 the engine was not hot. You could open the expansion tank by hand. The truck would go into limp because the guage was stating hot. While I didn't have a fancy temp gun I could tell by lifting the hood that it was not running hot. There was no evidence of over heating. Like I said you could open the expansion tank without any danger.
Just a thaught.
__________________
Michael
  #5 (permalink)
Old 10-25-2009, 12:04 PM
How can I test the fan to see if its bad?
  #6 (permalink)
Old 10-25-2009, 07:39 PM
boxcar1974's Avatar
Testing the clutch is pretty simple. I have changed a number of fans on my work earth moving equipment. Most of the time the spring has failed. On my chevy I am not sure if it was the spring or not.
Saturday Mechanic - Fan Clutch Replacement - Popular Mechanics
__________________
Michael
  #7 (permalink)
Old 10-26-2009, 01:35 PM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
Did you change the cylinder head temp sensor? A long time ago, one or two people had this exact same thing, and it turned out the PCM was bad, but don't go jumping to conclusions
It could even be an air bubble in the coolant.
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #8 (permalink)
Old 10-26-2009, 05:20 PM
boxcar1974's Avatar
Art, when I had my issues I too thaught about air in the coolant. I even jacked up the front end up as high as I could and idled the engine with the expansion tank cover off to let any air escape.
__________________
Michael
  #9 (permalink)
Old 10-26-2009, 07:12 PM
Changed the temp sensor and swaped the PCM with another truck,still doing same thing. Talk to a mechanic at the local ford dealer and he said try the insturment cluster but he also said that the truck would have to be reflashed to run. He also said that he couldn't believe that the truck ran after we swaped the PCM and didn't have to reflash it. Anyone know if this is true or not? Also had a mechanic check out the clutch fan he said it was good. It would spin with engine cold and when the engine warmed up checked it again and it was hard to turn.
  #10 (permalink)
Old 10-26-2009, 09:44 PM
Krewat's Avatar
If you swapped the PCM from a truck that is the same year and engine, well, chances approach 100% that it'll run.
Check the wiring, sounds like something is shorted or open.
__________________
  #11 (permalink)
Old 10-29-2009, 09:14 AM
Ok now I have found that the expansion tank is filling up and running out. The engine block temp is around 180, the head temp around 165 ,the radiator is around 135 ,coolant at the hottest in the expansion tank is 153,Bottom radiator hose 103. No oil showing up in water or water showing up in oil. Temps aren't hot. Still all you have to do is turn key off for 5 sec turn key back on good to go,for a little while. The gauge will heat and cool on its own several times very quick. If it helps 03 v10 with engine block heater. This is about to drive me nuts.
  #12 (permalink)
Old 10-29-2009, 11:39 AM
gremlintim gremlintim is offline
gremlintim is starting off with a positive reputation.
False Overheat on V-10
You know, this subject has come up a lot the past couple of years. I had a very similar experience in '06-'07 and here is the thread on this forum.
http://www.ford-trucks.com/forums/51...g-problem.html
I know how frustrating this problem can be.......
I'm pretty sure there is a service bulletin at Ford about this issue.
Good Luck,
Gremlin
  #13 (permalink)
Old 10-29-2009, 06:22 PM
Pulled the codes have a P1285 and P1299. The computer is showing it reached 255 degrees. I have shot every possible place with temp gun nothing is giving a hot temp really not even getting normal temp.
  #14 (permalink)
Old 10-30-2009, 12:30 PM
Yep....... 1285 & 1299 are the same two codes that would pop on mine everytime it went into false overheat mode.
  #15 (permalink)
Old 10-30-2009, 12:36 PM
Krewat's Avatar
Funny how "255" is exactly 8 bits of 1's. In other words, it's the highest number in binary that can fit in 8 bits.
__________________
Tags
antifreeze , change , enegine , ford , gauge , heat , hoe , jump , overflow , place , radiator , sensor , tank , truck , v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
