Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-24-2009, 10:47 AM
CobraGT40's Avatar
CobraGT40 CobraGT40 is offline
CobraGT40 is starting off with a positive reputation.
Question Programming door lock code ?
I just bought a '98 Explorer Sport and it has a few issues that need to be fixed. It didn't come with an owner's manual so I was wondering how I can program the door locks ? The key fob is easy, same as my Superduty... but how do I program the panels on the outer door ?
Thanks !
Scott
  #2 (permalink)
Old 10-24-2009, 06:16 PM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero is gaining momentum as a positive member of FTE.
You'll have to locate the factory code on the anti-theft module. It's behind the left rear quarter trim panel. The code will be a 5 digit number in bold print on the tag on the module.
You can view/download your owners manual here:
https://www.fleet.ford.com/maintenan...ls/default.asp
__________________
________________________________
"Information is valued and appreciated...Attitude is not!"
Steve,
'98 F150 Super Cab 4x4 SOLD, '99 Mustang 35th,
'02 Sport Trac 4x4, '01 Sport Trac Job 2 donor vehicle
'08 E250 Super Duty, No more Ranchero
  #3 (permalink)
Old 10-26-2009, 01:50 PM
CobraGT40's Avatar
That did the trick...thanks !
Scott
  #4 (permalink)
Old 10-29-2009, 02:33 AM
repair1 repair1 is offline
repair1 is starting off with a positive reputation.
hi
Programming keyless entry codes (driver door panel keypad).
The computer module is located inside the same cargo area side storage panel that contains the jack. The 5 digit code taped to the computer module is the factory set code.
To erase any personal code set by the prior owner, use these steps:
1. Use the keypad to enter the factory set code.
2. Within five seconds, press the 7/8 and 9/0 buttons simultaneously.
3. The system will now respond only to the factory set code.
You can program your own personal code via these steps:
2. Within five seconds, press the 1/2 button
3. Within five seconds, begin entering your personal five digit code.
(Each subsequent keypress must be within five seconds of the previous)
4. The system will now respond to both your new personal code and the factory set code.
5. Put the factory set code you wrote down in a safe place. It will always open your door, and it won't do you any good if locked inside your vehicle.
If you have trouble, see the owners manual section "Controls and features" or the index for "Keyless Entry System".
ipod repair solutions
cheap apple-ipod service
xbox 360 repair
Tags
2005 , 2007 , code , default , door , explorer , find , ford , lock , mountaineer , program , programing , programming , truck , trucks , unlock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
