Ordered headers!....What type of header bolts do I need?
I just ordered headers and I'm reading about the bolts being to short. Are there any particular bolts better than another. FYI I ordered Ford headers & the salesman said the "Stage 8" hardware is no longer avail.!? I was debating on contacting ARP. Any suggestions?
The parts guy couldn't tell me the thickness. I'll just have to wait & see. I actually wanted the Banks but $$$$, Too much difference in price (I may be regretting it later). Anyway, So they ARE metric. I've heard stainless, gr5 steel, gr8 steel, nickel coated, you name it. I guess dissimilar metal corrosion is what I'm getting at. And how deep into the head (I would assume 3/4" at least 5/8")....... Unless I'm misunderstanding your length doesn't seem right.
I thick the Ford headers might have 3/8" flanges. M8x1.25x25mm will do the trick if the flanges are 3/8" thick. Right now I have the grade 5s that came with my Thorleys.
Looks like you can get the 6.8l Stage 8 header bolts yet. Although I think getting the tabs and e clips on is going to be a real *****.
Stage 8 Locking Fasteners 8905 - Stage 8 Locking Header Bolt Kits - Overview - SummitRacing.com
If I get another loose header bolt on my Thorleys I think I'm going to get these. Percy's High Performance - - SummitRacing.com
I have one of the studs that came out of my 04' and it screwed into the head 5/8". I'd say you could get at least 3/4" of bolt in the head without bottoming out.
3/8" flange, That sucks!.....I was expecting a little longer bolt since it was going into aluminum instead of steel (But, I guess it would be that much less to drill out down the road LOL!) I looked at the thorleys, But I wasn't crazy about jacking the engine way up in the air (as the install instructions called out), and I thought I had seen where the frame rail had to be trimmed to make them fit?!?.....I aquired an exhaust leak w/broken studs, that's why I'm doing this.
Brown Falcon
10-23-2010 04:41 PM
leslane
10-04-2010 04:45 PM
oranjooose
09-18-2009 12:08 AM
fordtruggy
08-15-2009 09:24 PM
