Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-24-2009, 05:37 AM
YamakidCR500 YamakidCR500 is offline
YamakidCR500 is starting off with a positive reputation.
Flathead bellhousing bolt pattern
Is there a newer engine that shares the bell housing pattern of the flathead V8 (if that makes any sense)? The truck in question is a '48ish style F3.
  #2 (permalink)
Old 10-24-2009, 10:47 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
ALBUQ F-1 is gaining momentum as a positive member of FTE. ALBUQ F-1 is gaining momentum as a positive member of FTE.
Nope, but there are plenty of adapters made to mate up to the light duty trannys. Which trans do you have, the 4-sp with no synchros? If you are looking to re-power, you would probably be better off putting in a whole new matched engine/trans combo.
__________________
Ross
1952 F-1 Flat V8 3-on-the-tree
MSD dizzy, 2110 Holley, Red's Headers
  #3 (permalink)
Old 10-24-2009, 02:53 PM
Alright, thanks!
  #4 (permalink)
Old 10-27-2009, 10:13 PM
I was wrong on the F3 part, it is in fact an F4, is that a 1 1/4 ton?? Are the body parts the same size as the f1s and 2s etc...??
  #5 (permalink)
Old 10-27-2009, 10:18 PM
BlueOvalRage's Avatar
BlueOvalRage BlueOvalRage is online now
BlueOvalRage is starting off with a positive reputation.
The F-2 is considered a light duty 3/4 ton and the F-3 is a heavy duty 3/4 ton. The F-4's are the one ton trucks. The sheet metal is all the same from F-2 through F-6. The F-1's are the same as well for everything except the fenders. They will interchange, but the wheel opening is smaller. F-7 and F-8 Big Job trucks have the same cab, but I think most of the front sheet metal is larger and wider.
__________________
Let's agree to respect each others views, no matter how wrong yours may be.
Tags
flathead , swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
