Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-23-2009, 08:26 PM
460/5's Avatar
460/5 460/5 is offline
460/5 is starting off with a positive reputation.
Question Dart Heads?
will this top end kit work on my 400 if i get some spacers for it?
Dart - Top End Kits
__________________
Trey, aka Stretch, aka Slim, aka Shorty, aka Seven-Footer, aka Daddy Longlegs.
'91 F250 red long box super cab w/ 460, 5 speed, 4x4.
'76 F100 tan custom single cab short bed w/ 360, 4 speed, NP205 4x4.
'78 F150 white single cab long bed w/ 400, C6, NP205 4x4.
Imagine what I could do if I had all my brain cells.
  #2 (permalink)
Old 10-23-2009, 08:34 PM
Countrywfo's Avatar
Countrywfo Countrywfo is offline
Countrywfo is starting off with a positive reputation.
what kinda spacers you talkin about? an when i built my 400 i had the stock heads ' warmed over' a little cause i didn't know they even made aftermarket heads for the 400.
  #3 (permalink)
Old 10-23-2009, 08:45 PM
460/5's Avatar
Quote:
they make spacers that go between the heads and the intake to compensate for the larger spaces created by the taller deck height of the 400. usually used in the case of using cleavland heads on the 400 or 351M.
__________________
  #4 (permalink)
Old 10-23-2009, 08:53 PM
Countrywfo's Avatar
Quote:
i didn't know this, well i guess you learn something new everyday. An yeah i dnt see why it wouldn't work, although when i looked at the link you posted on the application chart all i saw was 302/351w. You sure the heads will bolt to the block?
  #5 (permalink)
Old 10-23-2009, 09:06 PM
460/5's Avatar
thats why i was asking. idk if windsor heads will fit.
__________________
  #6 (permalink)
Old 10-24-2009, 02:33 AM
grclark351 grclark351 is offline
grclark351 is starting off with a positive reputation.
why not just use Trickflow heads and no spacers?
search this forum for 'Windsor heads' and see what comes up, it's been explained several times. there's no reason to go to all the trouble to use Windsor heads on a 335 series
  #7 (permalink)
Old 10-24-2009, 04:34 AM
460/5's Avatar
is it that they will bolt on but cooling and oil passages are different? sorry, couldnt find a good thread discussing the topic.
__________________
  #8 (permalink)
Old 10-24-2009, 05:09 AM
460/5's Avatar
ok. well never mind. ima just get creative with a dremel grinder, and use some beehive springs... :P
__________________
  #9 (permalink)
Old 10-24-2009, 03:47 PM
Countrywfo's Avatar
You might wanna check out pawinc.com. they have stainless valves, roller rockers, and a adjustible valvetrain kits for the 400. they have some purty neat stuff there for that motor, was the only place i could find my forged pistons for mine.
  #10 (permalink)
Old 10-24-2009, 11:16 PM
yes the coolant flow path is different, a 'reverse Clevor modification' would need to be done. pushrod length would likely be custom, and you'd need a valley cover that seals tight. that you were planning on spacers the differences of Cleveland and Windsor intake bolt angles would work itself out, but the front accessory brackets might not have anything to bolt to? the intake spacers might cause the distributor to interfere with the intake depending upon manifold design, you might need to raise the dizzy on a spacer or come up with another type of ignition system.
you were considering laying out $1700 for a top end, why not just do it the easy way?
Edelbrock, Trickflow, CHI and AFD all make 2V cleveland heads that will accept standard 351M/400 intake manifolds and not cause any other problems.
BTW, you can do as much harm as good if you don't know what you're grinding on. and heads after 1975 have restrictive exhaust ports that can't be fixed with any amount of porting. there's a water jacket in the exhaust port
  #11 (permalink)
Old 10-24-2009, 11:26 PM
460/5's Avatar
so do you think i should clean the heads i have (theyre on a 78) and take them in for core value, and get some 4V heads or earlier 2Vs so that i can port them out?
__________________
Tags
400 , cleveland , heads
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
