1965 f100 Custom Cab restoration - Ford Truck Enthusiasts Forums
Old 10-23-2009, 04:15 PM
Itsme7 Itsme7 is offline
Itsme7 is starting off with a positive reputation.
Since i havent really shown any pics of my truck, i figured i'd post some up. I picked the truck up last year around this time from my neighbor across the street for $3,000. She ran, but was a little rough. It was converted into a 351W w/C4 trans. She was a little rough around the edges, but the main body is there, and the frame is in great condition so it would be a good project. Here are a couple of pics of the begining and progress. Heres my photobucket album link if you want to see more :65 f100 pictures by itsme78932 - Photobucket
How she looks now.
On the cab i had to do a bit of patching on the floor, there was a little bit of rot. The body is basically primed, so no filler work done yet. There are some spots i cant get to with the body hammer, and i dont want to spend $300 on a dent puller i'll only use once. Everything is painted with POR15. Awesome paint that really seals everything up. The chassis has 2-3 coats, the cab has 2 coats with a coat of undercoating on the underside.
On the chassis, we've done quite a bit of work. Replaced all the shocks, had the kingpins done (were real loose and the company had a hard time getting them out with a 50 ton press), all new drum brakes around (drums, pads, wheel cylinders, springs, ect) new wheel bearings, axle seals, All new suspension bushings, and some other things i cant think of at the moment. The fenders, doors, hood are in the basement and will be worked on during the winter. Over winter i will also be collecting all the pieces and parts i need, so when spring rolls around she will be ready to put together. For the motor, im looking at a crate motor. Proformance Unlimited is local and they build some pretty nice motors. Im looking at their 420hp 351W with dart aluminum heads, edelbrock carb, MSD ignition, ect. For the trans im sending it out to Dynamic Racing Transmissions in CT. Building it for 500+ hp so it will last a long time with no problems, putting a manual shift valve body on it. Im getting real excited about the project, i just cant wait till its done.
Old 10-24-2009, 02:52 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
All Custom Cabs came with stainless steel windshield mouldings.
The windshield weatherstrip is specific for these mouldings, as it has a lip to install them.
All 1965/66 Custom Cabs came with hard plastic upper door trim panels, which were surrounded by stainless steel mouldings.
The reason I mention thase items is...they are missing from your Custom Cab.
The doors appear to have the screw holes where the mouldings were attached.
Old 10-24-2009, 01:06 PM
Thanks. I dont know much of what the interior looked like, as when i got it, all the interior trim and everything was gone, pretty much bare metal everywhere.
Old 10-25-2009, 09:09 AM
oldfordcoupe oldfordcoupe is offline
oldfordcoupe is gaining momentum as a positive member of FTE.oldfordcoupe is gaining momentum as a positive member of FTE.
nice work so far i wish my was that far along
Holley 4180 Emissions questions eriklane 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 03-24-2011 06:20 PM
New to the site. Would like to see your drag cars Shua General Automotive Discussion 0 02-14-2011 06:29 PM
well, I may not be a genius... dogmantra 1973 - 1979 F-100 & Larger F-Series Trucks 36 10-31-2010 09:30 PM
New Excursion this weekend OutlawNomad Excursion - King of SUVs 32 03-02-2010 09:29 AM
1965 f100 Custom cab headliner question Itsme7 1961 - 1966 F-100 & Larger F-Series Trucks 7 10-27-2009 05:07 PM
Tags
1965, 1966, cab, custom, door, f100, ford, forum, parts, pics, proformance, restoration, trim, truck, unlimited
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
