P0098? - Ford Truck Enthusiasts Forums
P0098?
Old 10-23-2009, 03:34 PM
gairforce1 gairforce1 is offline
gairforce1 is starting off with a positive reputation.
P0098?
i have a 07 f250 psd with about 70k miles on it. i have k and n intake and filter. it's throwing code p0098 air intake sensz circ high. wondering which sensor this is, and if it's a part to get from k and n, or ford? and if there's anyways to test it?
thanks
Old 10-23-2009, 06:30 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
You have two intake air temperature probes (IAT1 - is part of the MAF sesnor) and the downstream IAT2. Your IAT2 may have a short to ground.
Old 10-23-2009, 06:34 PM
where is the iat2 located and how to test. or should i just replace?
Old 10-23-2009, 07:24 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
the iat is next to the fuel/oil filter housing. its a 2wire grey connector. to test it I would look at pid values iat1 and iat2 when cold. most common is caused by a broken connector and it is no longer seated correctly.
Old 10-23-2009, 07:27 PM
thank you, i found the iat2 and the connector was just a little loose.
Old 10-23-2009, 07:51 PM
cheezit's Avatar
no problem
Auto-Step Dent fidel.medrano 2017 Super Duty 14 11-02-2016 12:29 PM
Coil replacement options whateg01 Modular V8 (4.6L, 5.4L) 7 09-30-2014 12:20 AM
Frame rust serious_lee 1987 - 1996 F150 & Larger F-Series Trucks 15 03-20-2012 08:43 PM
2004 FORD 6.0 F250 DIESEL WONT START killthe6.0forddiesel 6.0L Power Stroke Diesel 19 09-08-2011 06:08 AM
choppy tire wear on front only ??? mstaser 1999 to 2016 Super Duty 4 05-13-2011 05:01 PM
Tags
2003, 2005, 60, 60l, air, code, codes, diesel, f350, ford, iat, intake, p0098, powerstroke, powestroke, temp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
