ITP... Got an email today though saying that some diprocol gauges are on back order so it will be delayed 1-2 weeks but no big d.
look at the isspro they are great quality. also the trans temp is full sweep at no additional charge....
dependant on year. 03-04 dont have a factory boost gauge. 05+ have factory boost.
if i was to fill four slots
egt, boost, fuel, trans. the reason i would choose fuel out of the other ones is that later you could get a digital monitor to watch the other vitals. the egt and fuel pressure are not avalible thru the ob2 port. i would however want to monitor the engine coolant and oil temp along with the other 3
__________________
2004, f250, ccswb, 4x4, 6.0, psd, lariat, electric tcase, isspro boost/egt/trans, sct x2 w/spartan tunes, 315/75/r16 bfg km stock rims no lift
pretty much stock
I'm saving up for a DashDaq. It's somewhat pricey, however you get diagnostics, gauges, datalogging, performance data, and optional GPS all in one package.
Gauges add some street cred when rollin' against the ricers. DFLEX gave a good base to start from it just depends on what you want to see. The "big 3" are boost, egt, and tranny temp.
I was thinking the same. What ranges for each do you recommend? I have 04 6.0L Priodically use Predator Tow Tune to haul 5th wheel.
Surprisingly nobody recommended you ditch the Predator and go with SCT X3 with custom tunes or Spartans Phalynx if you have the $$$
__________________
'04 F250 KingRanch CC FX4 6.0 swb "BIG D" Tim
GO FLYERS!
Originally Posted by hubler13f When congress refuses to provide soldiers with the equipment to complete the mission. S.T.E.A.L. Sudden Transfer Of Equipment to an Alternate Location
So many gauges, so much useful info. Clay @ RiffraffDiesel has all the ISSPro's- they are very nice, and match the OEM Green Color VERY NICELY. You guys have all posted very good info. Everyone has different experience with different gauges, and I've found it's basically personal preference.
The ISSPRO performax series is all digital, and has a nice, very simple method of sending all data (from electronic sending units all going to one master 'sender') via a few wires, which can be picked up by each gauge. SO any gauge can plug into any wire; pretty cool. I was already on my way with Autometer, so there was no turning back. Plus I like analog gauges.
I used the Isspro HPOP gauge, but otherwise went Autometer because I have (in process of) blue led's behind all gauges and instruments/switches. A bit of customization and fun for me. I have 7 installed gauges with 5 more to be installed. Will post pictures when I'm completed.
Hard to beat a custom tuned SCT X3 from eric @ innovative. Also, Scangauge II is a pretty cool LCD OBDII Readout.
Make a list what most people say, as the gauges that are the most important, compile that list, and see what you really want to install.
Autometer makes:
1,2,3,4 gauge pods for the pillar instead of the handle.
Single pod for on top of the steering pillar
Dual pod for 2 gauges on the sides of the instrument cluster
Triple gauge pod for above the stereo.
Triple gauge pod next to the driver's right knee.
2,3,4 gauge pod for above the rear view mirror.
AND you can drill out a 2" hole on each side of the steering wheel
Electronic/Digital = good (and easier to install in most cases)
Analog = BEST (imo) because you have true/real readings (more difficult to install)
EGT = a must to save from melting the cylinders, especially if tuned OIL TEMP = good to monitor vs h20 temp H20 TEMP = same as above (oil/h20 should be close to 20 degrees apart, no?)
OIL PRESS = pretty important, as it's related to hpop HPOP PRESS = will save your injectors when hpop starts to go FUEL PRESS = will indicate bad pump or clogged filter
VOLTS = good to see if batteries are going bad AMMETER = good to see alternator working
BOOST = good to see if issue with turbo TRANS TEMP = important if you tow DIFF TEMP = important if you tow
I also added an autometer clock.
I've seen many people request info about problems they are having, and many, if not MOST of those problems would be quickly solved if they had some meter readings.
__________________
2003 F350 6.0L CC LB 3.73s (Daily Commute)
- 10.5" Donahoe Racing Springs / 39.5" IROKs / Dual Fox Shocks
- 4" Turbo Back SS Exhaust / ARP Headstuds / SS EGR Cooler
- Banks Intercooler-Intake / aFe Intake Filter
- Magnafine PS Filter / DieselSite Coolant Filter
- SCT X3 Custom Tunes from Eric @ Innovative
If you need blubs for your Autometer Guages here is a site with GREAT PRICES:
superbrightleds.com
Model # WLED-X (194 Type)
Wedge Base Bulb
Price 1.40 each
