Still stuck on tranny problems...need help fast
So today I went to go and get my transmission flushed. It has been acting up for around 5 days now. I had to turn around and limp the truck home because I thought that I wasn't gonna make it. I thought at first that it was going out, but I'm not too sure now. On my way to the shop, the tranny started to give out. If I was just driving it easy, it would go through first gear then begin to shift to second but there would be no power I could rev the motor up but it just wouldn't move. It was like it was playing around in between gears. It did this in all the gears and the shifts were very weak. If I put it in the 1 position on the colomn and drove, all the power was there. It only gives out when it shifts. The shifts seem to be very delayed (about 5-8 seconds) and there is absolutely no power in between them. I can feel the tranny playing around like it wants to shift but it just takes it forever to decide which gear to go into. I also noticed that when I stopped at a light or stop sign, the tranny would not shift down into first until after the light turned green and I had already hit the go pedal, then it would SLAM!!!! into first gear and I would be on my way until time to change to second and then it would play around in between the gears again. If I forced it to stay in one gear, all of the power was there. I'm going to do a tranny flush and replace the filter on it Sunday to see if that changes anything, but does this sound like my tranny is shot?
Pull the trans and rebuild or replace it.
took it to a rebuilder he pulled it a part and found that the diode clutch that ford put in 01s had went bad nothing else he fixing it right now and in stalling the tugger kit for me
I can come up with two possibilities.
First, your trans most likely has a mechanical diode one way clutch. If it does, it's dying. The other possibility is that one or more of your clutches are worn out. That will make the shifts long and slippery, but what's left of the clutch will usually hold once it gets the parts stopped. That's the difference between dynamic and static friction. It's a lot easier to hold something than to get it to stop.
Darrell, you are the MAN! I tried to rep ya, but the rep police got me. Thats awesome man, plain and simple.
I have some new news. I took the truck out yesterday after it sat for two days. The tranny didn't give any trouble. I was driving for about an hour and a half. Later on yesterday evening I went for a ride again, but this time I put it in the 140 tune on my DP and it started acting up, but only after it got warm. What is this a sign of? I will be replacing the Transmission filter and the fluid today to see if that helps anything.
Agreed, there is no reason a trans flush should affect a properly operating transmission. If anything, it will help it.
Anytime anyone ASKS for a trans flush, I always question why. Many times you find someone trying to fix a problem on an already suspect transmission and they seem to "forget" they were having an issue if the flush is done and the trans messes up or fails.
