Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-23-2009, 03:07 PM
Brooksd1991's Avatar
Brooksd1991 Brooksd1991 is offline
Brooksd1991 is starting off with a positive reputation.
C6 Transmission Temp Gauge
I have an 84 f150 i do quite a bit of mudding pulling and just playing in. Its got a 351w and a c6 transmission i recently blew my last transmission and has to drop over 1k on a remanufactured one. I dont wanna do this again so i wanted to know if i could install a tranny temp guage on a c6 and if so how is it done and what are the steps?
  #2 (permalink)
Old 10-23-2009, 08:29 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. is gaining momentum as a positive member of FTE. mark a. is gaining momentum as a positive member of FTE.
1k for a "rebuilt C6" ? What a complete rip off. Fix what you got, even with a reman converter you won't have near that in it. Make sure you flush your lines and cooler out real good before putting it back in. While it's apart you can put a gage kit in it.
__________________
'79 F250 13" lift 42" Super Swampers
  #3 (permalink)
Old 10-23-2009, 10:44 PM
Quote:
Its not rebuilt its remanufactured and small block c6 4x4 trannys arent real cheap even for rebuilt ones and a rebuild is gonna run you around 700 so why not buy a like new remanufactured one.
  #4 (permalink)
Old 10-23-2009, 10:45 PM
Ya i figured out that i gotta get a pan with a drain plug and put my thermostat in there and run the line. I found a pillar for my truck but i think it would look a little weird so i might go with a dash mount
  #5 (permalink)
Old 10-25-2009, 07:19 PM
andyman7931's Avatar
andyman7931 andyman7931 is offline
andyman7931 is starting off with a positive reputation.
I cut the line to my transmission cooler and plumbed in a T. It's not the true temp of the casing, but I think it's good enough for what I do (heavy towing)
__________________
1989 F-150 XLT 4X4 351/c6 3.73 gears
  #6 (permalink)
Old 10-25-2009, 08:34 PM
archangel archangel is offline
archangel is new and has a neutral reputation at this point.
You could put it in the line going to the cooler, coming from the cooler or in the pan.
I think the pan would give the best average temp.
But putting them in the cooler lines would let you know the heat out and into the trans.
__________________
Gray 1991 F250 standard cab, 7.3, E4OD, 3.55:1, stock wheels and tires.
Verified 19 mpg city taking off slow as hell the shutting down at red lights, and with the radiator grill blocked flush, no bed cover, "drag shoot" mirrors on I get 24 mpg at 50 to 55 mph on the freeway empty!
However, with a bed cover, no mirrors and Hydroxy
  #7 (permalink)
Old 10-27-2009, 07:47 PM
true but i wanted a case temp and i said wanted in past tense because i am in the midst of selling the truck. But im not straying away from fords im gonna get an 87 ford 4x4 ext cab 300 inline 6 standard 3 inch suspension lift 3 inch body 33x12.50r15 mudkings....yeah boy
  #8 (permalink)
Old 10-27-2009, 08:03 PM
The I would find a clear spot in the bottom of the pan under or near the place where the filter picks up the fluid so you don't end up with stagnant fluid fooling the sensor.
__________________
Tags
c6 , f150 , f250 , forum , gauge , kit , operating , problems , specs , temp , temperature , tranny , trans , transmission , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
