Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-23-2009, 01:29 PM
96fordsport 96fordsport is offline
96fordsport is starting off with a positive reputation.
96 explorer 4wd indicator light
I have a 1996 ford explorer sport 4x4. Recently fixed the power windows and 4x4 via replacing the relay under the dash. All is good now but when I turn on the headlights the 4wd indicator light goes out. Any ideas ?????
  #2 (permalink)
Old 10-25-2009, 05:28 PM
donnor donnor is offline
donnor is starting off with a positive reputation.
light or no light...
It is possible that you disturbed a ground connection during your procedure & missed properly reconnecting it during reassembly. Is the 4x4 light on all the time or only when you are actually in 4WD? Does the brightness vary with the switching on or off of the lights? Such conditions usually point to a missing, loose, or intermittent path to ground. Are you sure you got the correct relay for your vehicle? Sometimes componets from one model may physically fit, but not share the same electrical connection configuration.
dn.
__________________
95 F350 C.C. XLT-daily driver / 95 F150 S.C.-"beater"
96 Explorer Limited - wife's ride
96 Bronco XLT - *surplus*-->wife says "sell"-->Sold!
92 Bronco Eddie Bauer - Son's ride
94 Bronco Custom - awaiting mods & buildup
96 Bronco Eddie Bauer - pieces & parts source
  #3 (permalink)
Old 10-26-2009, 08:36 AM
The relay was the same one. Solved the power windows not working and fixed the 4wd not working, same relay. Did not mess with any ground wire but may be possible. I don't think that is that though. The 4wd light is strong and constant, does not vary brightness. Doesn't seem as a ground issue. As soon as I turn on the lights, 4wd indicator light goes off. Turn lights off, 4wd indicator light goes on. You can do this all day long and it doesn't fluctuate in any way. I am wondering if it is in the switch relay in the relay module #4 box ?? Weird how the 4x4 light is interconnected with the windows, maybe the running lights are somehow connected with the 4x4 light. I saw a thread on this on another web site a month a ago but can't find it now. Seems I hear a relay in the back of the truck click when I turn running lights on and then off.
  #4 (permalink)
Old 10-26-2009, 08:42 AM
  #5 (permalink)
Old 10-28-2009, 01:47 PM
dan8052 dan8052 is offline
1985 Ford Mustang
My Garage
dan8052 is starting off with a positive reputation.
Tell me more about this relay. I have a 96' with the same issue (windows won't work when 4x4 light is blinking). Where can I find the relay under the dash, how much does the relay cost? Thanks for your help!
Dan
96' Explore - 173,300 miles... Still running strong.
04' Explore - 74,000 miles... Just bought it for the wife.
  #6 (permalink)
Old 10-29-2009, 12:58 PM
1996 explorer sport 4x4 light and windows
This is super simple and works to fix it. See the relay that controls the windows is the same relay that does the 4wd indicator light. Take off the plastic panel under the steering wheel, the take off the metal piece too. Look under there by the gas pedal. Up to the right is a black plastic box maybe 5" x 3" with black tape around it. Cut the tape off, pull the cover off, there are clips so be careful not to break them. Real bad position to work on all this. Anyways, there are 2 kinds of relays in there, a bunch of little rectangle ones and one big square one. The big square one is the problem, just pull it out, maybe some wiggling may be needed. Pull it out and bring it into autozone and they can match it. It is called the acc. relay. It was $7 at autozone and $12 at the ford dealer. Replace it and you should be good to go. If you need the part number of the relay I can get the one I got. PLEASE let me know if this fixes your problem. Also does your 4wd light go out when you turn on your headlights ? That is my problem. Hope this helps, I stiill need a solution for my problem of the 4wd light going out when you turn the lights on.
  #7 (permalink)
Old 10-29-2009, 02:49 PM
1985 Ford Mustang
My Garage
I've gone without windows going down for 3-4 years now (Thank god for Ford's cold AC). I read about the large electrical connector on top of the transfer case... unpluged it a couple of times, cleaned it, lubricated it up and it would fix the problem for a day or so then go back to lights blinking and windows not moving. Man, I hope this corrects the problem for good. Thank you so much for the quick reply. I will keep you posted with my results.
  #8 (permalink)
Old 11-08-2009, 12:44 PM
1985 Ford Mustang
My Garage
Found the relay, it was right where you said it would be, took it to Advance Auto and they said the relay is a turn signal/flasher relay. Is this the correct part or did I pull the wrong relay out? Thanks for all of your help.
Dan
  #9 (permalink)
Old 11-09-2009, 01:46 PM
1985 Ford Mustang
My Garage
Thank you! Thank you! Thank you! I love this website! Replaced the relay and all is well. My windows work again after all of those years. I believe the relay is only for the windows... my 4x4 lights still blinked with the relay out of the car, as well as all turn signals/flashers. $12.00 part from Ford and all is well. Thank you again.
  #10 (permalink)
Old 11-11-2009, 03:41 PM
does your 4x4 light go off on the instrument panel if you turn on your headlights and the selector is still on 4x4?
Tags
02 , 4wd , 4x4 , 96 , auto , blinking , explorer , exployer , flashing , ford , indicator , light , location , problems , relay , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
