Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-23-2009, 12:51 PM
B Dobz B Dobz is offline
B Dobz is starting off with a positive reputation.
Sliding Door question
1996 aerostar extended van and the side sliding door that has the little metal connectors for the electrical things like the door chimes and power locks and whatever the little rounds metal tab broke off and the rest are not far behind,can your get these new or what?thanks for your help.
  #2 (permalink)
Old 10-23-2009, 10:53 PM
CarCrazy1001's Avatar
CarCrazy1001 CarCrazy1001 is offline
CarCrazy1001 is starting off with a positive reputation.
Can you get them NEW?
- I doubt that any place would have those tabs NEW.
The same thing happened to me, i don't know how but one fell off and I was getting a false DOOR AJAR light on my dash. My solution was to take a small piece of tin and bend it and jam it in the slot. Its been 5 years since I did it so it works for me, but feel free to put any type of conductor in there.
  #3 (permalink)
Old 10-24-2009, 12:09 AM
aerocolorado aerocolorado is offline
aerocolorado is gaining momentum as a positive member of FTE. aerocolorado is gaining momentum as a positive member of FTE.
As stated above, I imagine these are discontinued items. However, you can pry the rubber grommet loose, extract the existing wiring and fabricate a new tab from thin sheetmetal, bottom of a metal coffee can, etc. Solder the new tab in place and re-insert in rubber grommet. For the remaining original tabs, you can simply move the grommet 90 degrees to furnish a newer contact surface. I pried mine up just slightly as well. Same goes for the contacts on both the door jamb and slider.
  #4 (permalink)
Old 10-28-2009, 09:07 AM
Hey I found these I think these should work on our vans
Streetrod Stuff - Ignition & Electrical - Painless Jamb Tac Wireless Connectors
  #5 (permalink)
Old 10-28-2009, 11:24 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar is starting off with a positive reputation.
Those certainly look like they could be adapted to the application. It would take so wiring skill and some drilling. You will need to make sure the holes get properly sealed, but these contacts look like the way to go.
  #6 (permalink)
Old 10-31-2009, 10:20 PM
99f350sd 99f350sd is offline
99f350sd is gaining momentum as a positive member of FTE.
Junk yard for sure..
__________________
99 F350 5.4 Lockers,Warn winch,Hubs..MDII Plow, 200 amp alt timbrens,Revo's
85f150, THREE 96 aero*awd 4.0 ext.
05 mountaineer V8 Awd
USAF 76-80
Tags
aerostar , door , sliding
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
