Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 11-03-2009, 12:29 AM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
Pinion bearing preload
Just to elaborate on the "putting the pinion nut back where it was" idea; it's a bad idea. If you replace the pinion seal and don't know how tight the nut should be, consider the fact that the bearings have probably worn and the nut may have backed so. The pinion bearings like to run snug and using a torque wrench the check "rolling torque" when there are no torque specs for a pinion in a vehicle full of grease the best method (vs counting the threads) is to preferably get a new nut and run it down until there is a noticable drag on the pinion. The crush sleeve will spring back a few thousandths after being relieved of the original crush and the slack hasn't been taken up by the worn bearings so in effect you already have a new crush sleeve in there. This in conjunction with the new nut will assure a secure unit and a proper preload on the bearings. I have seen pinions with so much drag on them they were hard to turn by hand (after thousands of miles) and they worked perfectly so the torque is not that critical but you do need some drag on the bearings.
__________________
Brent Bradley Scenic photographer and former mechanic with car and motorcycle drag racing background. Also, avid snowmobiler.......retired. The Ex; custom mudflaps
  #32 (permalink)
Old 11-03-2009, 12:46 AM
AlaskaJeff's Avatar
AlaskaJeff AlaskaJeff is offline
AlaskaJeff is starting off with a positive reputation.
Quote:
GREAT information, thanks Greg! What is the rational used in the recommendation for using a NEW pinion nut? I can see IF it is a nylon insert style nut. I was an aircraft mechanic in the AF and had MANY nuts that were 1 time use, mostly all had the nylon insert tyhat would loose it's grip ( so to speak) if you were to reuse it. But we were working on critical aircraft components.
__________________
Jeff Reichel
03 F250 V10 King Ranch Crewcab, Mildly Modded Daily Driver
Palmer, ALASKA
CHRIST for LIFE!
Phil 4:8
  #33 (permalink)
Old 11-03-2009, 01:11 AM
EXv10's Avatar
Quote:
Many pinion nuts are the self locking type. Just added insurance, you probably wouldn't need it.
__________________
  #34 (permalink)
Old 11-03-2009, 08:15 AM
MoyockPowerstroke's Avatar
MoyockPowerstroke MoyockPowerstroke is offline
MoyockPowerstroke is gaining momentum as a positive member of FTE.
Counting to ten......
__________________
Real Trucks Don't have Spark-Plugs '05 6.0L, Lariat 4x4, 83k miles, Racor CCV6000 Filter, Oil Bypass Filter, Fumoto, Coolant bypass, ZooDad, BullyDog 4" TB 4"DP (BullyDog ate Kitty), SCT SF3 Perf Strat, 24" Wipers, '08 Rear Diff Cover, Upfitters, Skyjacker/Russell brakes lines, M/C Max 100 BXT-65-850s, Mobil1 Syn 5W-40, Wagner ThermoQuiet's, Stanadyne Perf Add & FPPF Lubricity+Power Add., Prodigy Brake Controller, Nitrogen filled Bridgestone Dueller A/T Revo's, Satellite radio, Sun-visor.
Tags
150 , 2002 , additive , f150 , f250 , ford , heavy , leak , leakingf250 , leaky , pinion , psd , rear , remove , replace , seal , seals , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
