Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 10-25-2009, 12:14 PM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
14; The pinion bearings are supposed to run snug and when you just put the nut back where it was the pinion will be as loose as it was before and the nut will be loose also and could of back off. At least use a new nut if you use this inferior method. I didn't say anything about rolling torque but having a light drag on the pinion is 10 times better than the "counting the threads" method. I guess the guy that fixed hundred of rear ends never learned anything.
__________________
Brent Bradley Scenic photographer and former mechanic with car and motorcycle drag racing background. Also, avid snowmobiler.......retired. The Ex; custom mudflaps
  #17 (permalink)
Old 10-25-2009, 01:09 PM
EXv10's Avatar
The shop manuals are full of facts, figures, and specs but the seasoned mechanic doesn't have his nose in the book half the day. I have seen many of used rear ends with no drag on the pinion that worked perfectly and some that worked perfectly with so much drag on the pinion still after thousands of miles that you could barely turn the pinion by hand. When I set up my first few pinions I checked the torque and never checked one with a wrench after that and never had a problem. 14; don't listen to me? No, listen to the guy that never was a mechanic. It's uninformed people like you that spread bad info in here.
__________________
  #18 (permalink)
Old 10-26-2009, 12:59 AM
MoyockPowerstroke's Avatar
MoyockPowerstroke MoyockPowerstroke is online now
MoyockPowerstroke is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by EXv10 View Post
I have fixed hundreds of rear ends and counting the threads to get the nut back into place is a bad idea. You are not accounting for any wear of the pinion bearings and the possibility that the nut has backed off. Chances are the seal was bad in the first place because the pinion was loose. Thats like putting your boot laces back to the same tightness after going half way through a hike. Tighten the nut down until there is a slight drag on the yoke (like it is supposed to be). Go slow here so you don't have to back the nut off to attain the drag. Not only have you not accomplished anything but now the nut is loose and prone to backing out. Use a seizing compound also.
Listen...you started this with your ******* comment above. So yoiu say you're a mechanic, but again I submit that you offered no insight to how it should have been done by YOUR textbook or memory of having performed 100's of rearend jobs...you think you could at least offered the guy some assitance ...instead you down-play or degrade those on this forum who do at least offer advise and assistance...(and no i don't mean ..."Yeah going to the dealer is like going to the dentist"...get over yourself...please. Its guys like you who taint this forum with your constant bashing and no real answers...and by the way...I'm am currently attending college as an Automotive technician....so who knows maybe some day I could officialy call myself a mechanic...but I wouldn't brag on it unless I could feel I was truly helping someone. And the call sign is Moyockpowerstroke...not 14....whatever...
__________________
Real Trucks Don't have Spark-Plugs '05 6.0L, 84k miles, Racor CCV6000 Filter, Oil Bypass Filter, Fumoto, Coolant bypass, ZooDad, HighIdleMod, BullyDog 4" TB 4"DP (BullyDog ate Kitty), SCT SF3 Perf Strat.w/Edge Insight for gauges, 24" Wipers, '08 Diff Cover, Upfitters, Skyjacker/Russell brakes lines, M/C Max 100 BXT-65-850s, Mobil1 Syn 5W-40, Wagner ThermoQuiet's, Stanadyne Perf Add & FPPF Lubricity+Power Add., Prodigy Brake Controller, Nitrogen filled Bridgestone Dueller A/T Revo's, Satellite radio, Sun-visor.
  #19 (permalink)
Old 10-26-2009, 11:35 AM
aldridgec's Avatar
aldridgec aldridgec is offline
aldridgec has a very good reputation on FTE. aldridgec has a very good reputation on FTE. aldridgec has a very good reputation on FTE.
Moyockpowerstroke step back a little.
Just because you think EXv10 didn't detail the way he does it, he DID bring up an important point. While I agree both methods CAN work, the best way to do it is to set the bearing to the proper preload. Setting it back to the same spot only ensures you are probably not worse off than you were to begin with. I believe these differences were discussed in another thread.
Many of us that have done this for a long time can do it by hand, or compare the before to the after. There are specs for bearing preload, but if you are not going to be removing the tires, brakes, axles, (on a full floating rear you only have to slide the axle shafts out) and differential carrier, they are worthless because they only account for the pinion bearings.
The important thing is to consider all input while learning to do something, and since this is your first seal replacement, you are in no position to make a determination on what way has worked best for you, least of all which method is best.
__________________
Chris
ASE Certified Master Automotive Technician
Current Vehicles:
2002 F-250 7.3L PSD 4x4 XLT
2002 Sunset Orange Mettalic WS6 Trans Am Convertible
"Maybe is for those who lack skill"
  #20 (permalink)
Old 10-26-2009, 11:56 AM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart
2000 Ford F-350
SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of
Good post, Chris.
Let cooler heads prevail at FTE.
Thanks.
Pop
__________________
-Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks,
and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX.
Email SpringerPop
  #21 (permalink)
Old 10-26-2009, 12:41 PM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of
Good example here of why I said in the other thread that I wouldn't attempt this in the driveway. Avoiding this discussion, and the second thoughts that it is sure to inspire, would be well worth the $165 to have it done by an expert.
__________________
Folks call me Bill.
Please pass the GREEN nozzle.
2006 F250 XLT SCLB FX4 4x4 6.0L Auto,Magnaflow Turbo Back,RhinoLiner,Retrax Cover,Cab Lights Retro-fit,Overhead Console Retro-fit,Bilsteins,Harpooned,C-Betrs,Fumoto.'08 Diff Cover Fleetwood Pioneer,23'x5,200#
  #22 (permalink)
Old 10-26-2009, 12:46 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
Actually, I think both methods are flawed, without CHECKING THE PINION PRELOAD IN THE FIRST PLACE.
Pinion seals usually do not just start leaking on their own. There is usually a cause besides wear unless you have a huge amount of miles or the pinion seal surface rusted. Loose pinion bearings, or a clogged breather. I would definitely check the breather before it starts to leak again
But seriously, without removing the differential from the case and checking the real pinion preload BEFORE pulling it apart, you're playing with fire.
Yes, most mechanics do "count the threads", but they usually don't get a report back in 30K miles when it starts leaking again because it's loose, or the pinion bearings overheat because it went back together too tight.
If I ever have to deal with this on my Superduty (after having dealt with it on plenty of other rear ends, and having rebuilt quite a few too), I'm getting a new crush collar, a new nut, and doing it by the book.
Actually, if I ever have to deal with it, I'm going to use it as an excuse to upgrade from 3.73s to 4.30s
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #23 (permalink)
Old 10-26-2009, 01:48 PM
aldridgec's Avatar
This is also just good CYA procedure too. You do a pinion seal, and a few months down the road it's making noise, you were the last one to work on it. You could have set it back to accepted "used" bearing preload, or where it was before, but if there is an impending failure in the pinion bearings you wouldn't have known.
However, in practice this is rare IMO. Usually if something is going wrong, you will notice real looseness, noise or roughness beforehand and two, most people won't pay for that kind of tear down for a seal. I (want to) agree that any rotating seal shouldn't fail unless there is something else wrong, but it does happen. Could be dirt, water, manufacturing variance etc.
I think this is one of those cases where yes you are playing with fire, but you won't get burned, it will just explode. And the chance of exploding rarely happens. Kinda like airplanes are the safest form of travel, but when something goes wrong, it really goes wrong.
__________________
Chris
Current Vehicles:
  #24 (permalink)
Old 10-26-2009, 03:20 PM
All great points...I admit I was a little hot headed...EXv10...I apologize...lets bury the hatchet...we all need each other from one time or another and I hope we get along and make ammends. Thanks for everyone's comment and continued help and assistance.
__________________
  #25 (permalink)
Old 10-26-2009, 03:46 PM
EXv10's Avatar
Actually, just making sure you have a slight drag on the pinion when everything is buttoned up is a very good way to go. I have done it many, many times and it works very well. It sure beats taking it all apart right down to the lightly lubricated pinion and the torque wrench. Using a new nut when you do this procedure is a good idea also.
__________________
  #26 (permalink)
Old 11-02-2009, 10:13 PM
AlaskaJeff's Avatar
AlaskaJeff AlaskaJeff is offline
AlaskaJeff is starting off with a positive reputation.
BTW what is the torque on the 12mm driveshaft yolk bolts? The source I have shows 86 ft lbs, is that right? Also is there a torque the pinion nut SHOULD be at? I read a running torque of 8-14 in lbs and a breakaway torque of 20. Do these numbers sound right. I am just replacing the pinion seal.
__________________
Jeff Reichel
03 F250 V10 King Ranch Crewcab, Mildly Modded Daily Driver
Palmer, ALASKA
CHRIST for LIFE!
Phil 4:8
  #27 (permalink)
Old 11-02-2009, 11:14 PM
I did torque the 12mm12pt shaft bolts @ 86lbft...the Pinion Nut (of much debate) was returned to where it started plus 1/16th". I understand that where it started may have been wrong in the first place, but that was my reference point and since the companion yoke wasn't coming off without effort, I assume the bolt was not backing off on its own. I will keep a close eye on where I landed it. Use blue locktite or thread locker.
__________________
  #28 (permalink)
Old 11-02-2009, 11:32 PM
AlaskaJeff's Avatar
Quote:
Thanks, I'm going to be working on it tomorrow! I've got the new Aluminum diff cover going on too . MAN the 75W140 is SPENDY!!
I got Mobil 1 75W140 LS I'm going to put it in and see IF I need the friction additive on top of that. I picked up 8 oz of it but it looks like the Mobil 1 has some in it already?? I will take some slow corners on pavement or concrete and listen for the tires to scrub or not.
__________________
Jeff Reichel
Palmer, ALASKA
CHRIST for LIFE!
Phil 4:8
  #29 (permalink)
Old 11-02-2009, 11:38 PM
Yep, just ordered my '08 rear diff cover...should be here before the weekend. I will also be adding Mobil1...heard it already has the LS additive package already in the mix. Did you order the bolt set as well, heard longer bolts were needed with new cover?
__________________
  #30 (permalink)
Old 11-02-2009, 11:54 PM
AlaskaJeff's Avatar
I too heard they needed to be longer so I just went to my local NAPA and picked up twelve 1 1/4" long 5/16 18 pitch (coarse) grade 5 bolts. They were like .40 each!!
__________________
Jeff Reichel
Palmer, ALASKA
CHRIST for LIFE!
Phil 4:8
Tags
150 , 2002 , additive , f150 , f250 , ford , heavy , leak , leakingf250 , leaky , pinion , psd , rear , remove , replace , seal , seals , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
