Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1947 and Older Ford Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 11-07-2009, 08:55 AM
EricJ EricJ is offline
EricJ is starting off with a positive reputation.
I would go with the dual master at the very least, and the booster would be prefered. makes ahuge diffence with the booster if your sticking with drums, and the dual system is much safer, less apt to lose all your brakes at once.
  #17 (permalink)
Old 11-17-2009, 07:32 PM
46fordphil 46fordphil is offline
46fordphil is starting off with a positive reputation.
Continuing on
All, Just a short progress note. So far have completed redoing the brakes. Had put in a 9" 1965 rear to alter the ratio, and had to get new drums/brake shoes/etc. to get them completed. Sacramento Vintage had the master cylinder and front wheel cylinders/shoes. Was able to have the drums turned on the front, so all of that is ready to go. Napa was excellent with the rear brakes. They don't seem to have access to before 48 tho. Now am learning the plumbing for the system. Am using S/S lines and had a bear trying to 'double flare' the fittings and have decided to use AN from Speedway since the 37 deg is so much simpler to do. Hopefully can get the parts and have it together next week. Then on to get the Flathead, etc. back in. Anyone had any experience with flaring stainless tubing. Decided to use 1/4" tubing for most of the plumb with 3/16 only for the rear axle. Would like to know if there are any secrets on the flaring process. Thanks. phil.
  #18 (permalink)
Old 11-18-2009, 09:16 AM
COMPLIT1107's Avatar
COMPLIT1107 COMPLIT1107 is offline
COMPLIT1107 is gaining momentum as a positive member of FTE.
Flaring SS tubing requires special equipment ($$). It is much easier (but more expensive) to use SS compression fittings. You'll have to find a supplier of these fittings as they are used industrially, not at an Auto Parts store or a general hardware store. I did a '37 chev with SS lines and compression and it will never leak. Note, the ring seals need to be SS as well so they actually seal against the tubing correctly.
__________________
John
When it's fixed, I'm broke, When it's broke, I STILL AM!
Tags
12 , 1942 , 46 , 46ford , abs , assembly , brake , brakes , drum , ford , orangca , power , truck , trucks , upgrade , vintage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
