PCM location and removal. - Ford Truck Enthusiasts Forums
Old 10-23-2009, 09:44 AM
angelaborges angelaborges is offline
angelaborges is starting off with a positive reputation.
Have a 1990 F250 460cid EFI with a bad pcm. where is it located and how would I remove it . truck is 130m miles form a dealer. I am thinking of replacing it my self with a used one. but need the information on the curent unit. to find a repacement. so it needs to be removed.
this truck only has 38 thou. miles. was gifted to me. last owner had duis and could not drive it. reason for low miles.
Angela
Old 10-23-2009, 09:50 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
It's behind the drives side kick panel. To remove it first disconnect the battery and then get a 7/16" boxend wrench and unbolt the wiring harness from inside the engine bay. Then pull the plastic kick panel from inside the cab and remove the retainer clip keeping the EEC in the fender pocket. Remove it by lifting the rear slightly and wiggling it out of the pocket, the rubber gasket at the firewall will have a pretty good grip on the connector so it will take some persuasion to free. Apply some petrolium jelly to the outside of the connector on the replacement EEC to help ease it back in.
Old 10-23-2009, 09:53 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
It is located in the drivers side kick panel (between the door and the firewall).
You have to unplug it under the hood very low on the fire wall (10 mm socket).
Then remover the kick panel and take it out from inside the cab.
Old 10-23-2009, 11:02 AM
PCM removal
Thanks so much. I will head up to my Place and have ago at removing the PCM
again thanks so much for the help/\
Angie
Old 10-23-2009, 11:11 AM
subford's Avatar
What makes you think it is bad?
Old 10-23-2009, 11:51 AM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
i am also curious why you think it is bad.
Old 10-23-2009, 12:06 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
X2
Side note: I have always pulled the inner fender liner to pull the ECU from the engine compartment side. I never knew it could be pulled from the inside. Last I remember on my 2 previous '93 Lightnings it was impossible to pull from the inside. So much for having a keen memory!
Old 10-23-2009, 12:43 PM
subford's Avatar
Quote:
Originally Posted by rla2005 View Post
X2
We are talking about a 1990 here and if you look at the photo of the plug above you will see that it is impossible to be pulled out through the engine side. It can however be removed from inside the cab.
Yes on your 1993 Lightnings you have to remove it on the engine side and through the inner fender liner.
Old 10-23-2009, 01:07 PM
rla2005's Avatar
I fully understand the OP has a 1990. I'm just saying my '93 was pulled from the engine side. It always amazes me how Ford makes little changes along the way from year to year...
Old 10-23-2009, 05:59 PM
I have checked everything else. Ford Mech seems to think is pcm also. since engine will run is you spray starter fluid into the air intake. a used one is cheapest way for me to go. at this time. but I'm open to any sugesstions, and will check then all before pulling the pcm out
Angie
Old 11-10-2012, 05:54 PM
Dead Truck Dead Truck is offline
Dead Truck is starting off with a positive reputation.
I have a 1987 F150 - is the ECU under the drivers kick panel too?
Old 11-10-2012, 07:40 PM
I have a 1987 F150 - is the ECU under drivers kick panel too?
Old 11-11-2012, 09:57 AM
rla2005's Avatar
More than likely it is, I have never owned or worked on a 1987 model. Pull the panel off and look. If it is there it should be removed from inside the cab once you remove the connector.
Old 11-11-2012, 02:33 PM
What kind of tests can be performed without trying it in another truck? Mine wont run long enough to use a scanner and I don't know anyone with a truck.
Old 11-11-2012, 02:41 PM
rla2005's Avatar
You can run the Key On Engine Off (KOEO) tests which is followed by the Continuous Memory (CM) display.
What kind of issue(s) are you having?
Change PCM? tinman52 1999 to 2016 Super Duty 3 03-11-2015 10:15 AM
PCM removal - help needed mojo79 1987 - 1996 F150 & Larger F-Series Trucks 5 06-09-2012 09:55 PM
1994 bronco ecm/pcm computer location and removal airboatoutlaw 1978 - 1996 Big Bronco 0 03-05-2011 06:22 PM
2009 ford f250 ecm/pcm code sticker location? 6LPSD Modular V8 (4.6L, 5.4L) 1 04-07-2010 03:14 AM
location of the pcm code on a 2009 ford f250 6LPSD 1999 to 2016 Super Duty 8 04-06-2010 01:20 PM
Tags
06, 150, 1996, 1997, 2003, 93, f150, f250, ford, location, module, pcm, powertrain, ranger, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
