Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-23-2009, 09:34 AM
MikeRocks MikeRocks is offline
MikeRocks is starting off with a positive reputation.
Front Main Wheel bearings
Alright, I just put 315's on my 03 F250, and replaced my ball joints, all was good and quiet at first, but now I am getting a loud hum out of the front end (not sure which side?).
I figure that the main bearing must be going out. Is there any way to just replace the front bearings or do I need to replace the whole hub assembly (which my wife will certainly not be thrilled about)?
Thanks!
  #2 (permalink)
Old 10-23-2009, 10:08 AM
texans's Avatar
texans texans is offline
texans is gaining momentum as a positive member of FTE.
I take it you are driving a 4x4. If so then as far as I know you have to replace the whole asyembly
__________________
2006 F-250 Lariat C.C, 18" rockstars w/285/65 nittos, SCT w/custom tunes, Banks Ram-Air Intake, 5" MRBP exhaust w/o kitty, 2.5" levealing kit, readylift air bags, fumoto drain valve, Viper alarm with remote start, 2-10" MTX Subs, drilled and sloted front rotors, ARP studs sitting in shop waiting on other parts.
come Join the Texas Chapter!!
Scotty
  #3 (permalink)
Old 10-23-2009, 01:54 PM
brian42's Avatar
brian42 brian42 is offline
brian42 has a very good reputation on FTE. brian42 has a very good reputation on FTE. brian42 has a very good reputation on FTE.
What kind of a hum ? Your big tires will probably hum (depending on the tread pattern). Is is a grinding? Is it more pronounces at any specific time (accelerate, brake, turning)? Please be as specific as possible and we'll try to get to the bottom of it !
I just did my ball joints not too long ago and did not experience that. All I got was some moaning and groaning as the ball joints broke in, but all is good now .
__________________
THE MOOSE
2003 F-250 PSD 7.3 Lariat FX4 CC/SB, 4R100, 3.73LS, dual alternators with 188K+ Miles
AIH delete, In-Tank (ITP) and Harpoon Mod, SS HPX, 203F Thermo w/Billet Housing, FTVB, '08 Rear Diff Cover, Headlight Harness (GOS), Zoodad (King Style), 6637, Foil Delete, Engine/CAC boots (Dieselsite), Moog Ball Joints, BFG Mud-Terrain TA KM2 285/75-16
Real Men Redline Less Than 3500 RPM
  #4 (permalink)
Old 10-23-2009, 03:59 PM
yes its a 4x4...
and the tires didn't make much noise at all when they were first on, now the "hum" gets louder as I accelerate, but isn't that bad over 65mph. the sound doesn't change at all on asphault or concrete roads.
I stuck my head out the window and couldn't notice the hum, plus I don't hear it bouncing off any walls or anything that I drive by.
There is a vibration that I feel through the floor and through the steering wheel as the noise gets louder, but it also goes away at higher speads.
I have the new Goodyear Wrangler Duratracs (put on 2 months ago) and haven't lifted the truck yet, so for a while I thought that it was the tires wearing in and making more noise because they are tucked in the wheel well pretty good, but since it is getting louder each day, I figure it must be the bearings...
I changed the ball joints when I got the tires and started to notice the sound about 3-4 weeks ago.
hope this helps.
Thanks,
Mike
edit: Oh yeah, it sounds like I am running super swampers, but with a grinding feel in the truck. it gets pretty loud, but not outside.
  #5 (permalink)
Old 11-05-2009, 11:23 AM
update:
well changed the hubs out and to my surprise, the loud "hum" is still there... with 156k they needed to be changed anyways.
Now the question is what is the noise?
could it be from the new tires (they do have a pretty aggressive tread and sidewall) since I haven't lifted the truck yet? They are 315's on the stock suspension 4wd F250.
I also thought maybe I had a slight alignment problem, since they were quiet when I got them and then they started to get louder after a couple hundred miles. But the od thing is, is that the noise doesn't change with the road surface, even on dirt roads.
  #6 (permalink)
Old 11-05-2009, 11:53 AM
brian42's Avatar
The Duratracs definitely have a more aggressive tread pattern. Even though they have the staggered center section that reduces road noise, I'm sure that they are not quiet.
With the sound being more of a constant droning (and without hearing it first hand), it sounds to me like road noise from the tires.
I hear you on the hubs. I changed mine at 185K. Even though they had some life left, they'd lived a good life and it was time to retire them to be my spares. No reason to tear everything down and not put new stuff in there.
Not to be completely off-subject, how do you like the Duratracs? They are new and have not read much about them (especially on our front-heavy trucks). I almost bought a set, but changed my mind at the last minute last week.
__________________
THE MOOSE
  #7 (permalink)
Old 11-05-2009, 03:08 PM
senix's Avatar
senix senix is online now
senix is gaining momentum as a positive member of FTE. senix is gaining momentum as a positive member of FTE.
sounds like the tires to me. Anytime you run a more aggressive tread than what was there you are gonna have more road noise.
__________________
2008 F250 PSD Crew Cab 4x4, X-liner,
Cooper Discovery STT LT275/70R18's
Skyjacker dual steer stabilizer
Banks Ram Air & 6-Gun, Upfitter switches
Ravelco Alarm System, Frontier Extreme FT. Bumper
  #8 (permalink)
Old 11-05-2009, 03:44 PM
jlmotox's Avatar
jlmotox jlmotox is offline
jlmotox is starting off with a positive reputation.
I have noticed that tires will get louder once they start to wear down...
have you ever had a truck with all terrain tires? they are not quiet like the stock tires but not loud like a mud tire...
__________________
2005 F250 FX4 4x4 PSD Lariet cc sb srw
Mbrp turbo back exhaust, Airaid intake w/zoodad mod, Banks PDA ottomind, Warn 12,000lb winch w/hide a winch bumper, BFG AT's, Pioneer Navigation w/ XM, reverse camera, 10" JL audio sub, 15% tint, reverse lights (aka A-hole lights)
  #9 (permalink)
Old 11-05-2009, 06:49 PM
brian42's Avatar
I never really noticed any road noise from my Pirelli Scorpion ATRs (not like you can hear much above the cackle of the injectors ), but over the last few months I have begun to hear them (I've got 42K on them). I'll have to compare them to the BFG MT KM2s when I put them on this weekend...
__________________
THE MOOSE
  #10 (permalink)
Old 11-06-2009, 05:07 PM
Y2K1TON's Avatar
Y2K1TON Y2K1TON is offline
Y2K1TON is starting off with a positive reputation.
Find 2 wheels and tires to put on the front only temporarly to eliminate the 315's as making the noise. Do ya have a used tire shop around and some spare rims? If the noise goes away with different tires then it was the 315's making the noise.
  #11 (permalink)
Old 11-06-2009, 07:33 PM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
Even trying your spare should tell the story.
__________________
Brent Bradley Scenic photographer and former mechanic with car and motorcycle drag racing background. Also, avid snowmobiler.......retired. The Ex; custom mudflaps
  #12 (permalink)
Old 11-06-2009, 10:09 PM
FireMe FireMe is offline
FireMe is gaining momentum as a positive member of FTE.
I have also seen many people mistake a rear hub bearing noise for a front one, even well experienced people.
Worth checking out and costs nothing.
Jay
  #13 (permalink)
Old 11-06-2009, 10:29 PM
EXv10's Avatar
+1 on the above.
__________________
  #14 (permalink)
Old 11-08-2009, 11:06 AM
nitrogen's Avatar
nitrogen nitrogen is offline
nitrogen is gaining momentum as a positive member of FTE.
rotate your tires my tire guys suggest about about every 3-4k miles for aggressive mudders to keep them wearing evenly and to get the most life out of them. it can add an additional 10 20 k miles to tire life
__________________
2005 F350 Lariat crew 4x4
traded F350 XLT supercab 4x4 what a stinker
Tags
2000 , 2005 , 2006 , 4x4 , bearing , bearings , chaging , duty , end , f250 , f350 , ford , front , problems , replace , super , wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
