Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-22-2009, 11:15 PM
F-100CustomCabTBC's Avatar
F-100CustomCabTBC F-100CustomCabTBC is offline
F-100CustomCabTBC is starting off with a positive reputation.
Help Correct Fuel Pump?
Hi,
I bought this fuel pump and I just have a feeling that it isn't the right fuel pump for a 272. I bought it from LMC (prt # 43-4715) all it said was a fuel pump for a '57-'65 Ford V8 Fuel Pump. I called them up and they couldn't tell me anymore than I already knew. The slip that came in the box said that a pump arm that has a sharp bend in it fits a 221, 260, 351, 289, and a 302. And the pump arm that looks like the one pictured (a bump and a bend) fits a 352, 390, 468, 360, and a 410.
For me that raised a red flag. But I have no clue. The pump that came off of my original 272 looks more like the one with a sharp bend in it. It's like if you took the bump off the one picture and ran the two lines together and you get a sharp corner.
Does anyone know if infact that this pump does work on a 272?
  #2 (permalink)
Old 10-23-2009, 12:03 AM
charliemccraney charliemccraney is offline
charliemccraney is starting off with a positive reputation.
The pump pictured will work fine in a Y. The FE and Y block pumps use the same arm.
  #3 (permalink)
Old 10-23-2009, 10:26 AM
WALFORD'S 56's Avatar
WALFORD'S 56 WALFORD'S 56 is offline
WALFORD'S 56 is starting off with a positive reputation.
I also have a fuel pump question........where do the vacuum lines go to....on th top of my fuel pump.....there are 2.?
I just installed this 272 and my other yblocks do not have the 2 ports on top.
Sorry to barge in......and your pump looks correct to one of my other trucks.Bill
  #4 (permalink)
Old 10-23-2009, 11:51 AM
Quote:
Thanks for the input!!
Thanks and that's OK
  #5 (permalink)
Old 10-23-2009, 09:31 PM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is starting off with a positive reputation.
dont know, but did you get your Pertronix installed?
__________________
COLOR=Navy]1946 1/2 ton with Y-block
1964 F-250, 292 4 speeed
1990 Ranger 4WD
  #6 (permalink)
Old 10-23-2009, 09:34 PM
Usually, vacuum lines on the fuel pump power vacuum wipers.
  #7 (permalink)
Old 10-24-2009, 12:33 AM
Y-Blockhead's Avatar
Y-Blockhead Y-Blockhead is offline
Y-Blockhead is starting off with a positive reputation.
One side goes to the vacuum wipers as Charlie stated, The other goes to the intake manifold. The purpose of the vacuum pump is to provide vacuum to the vacuum wiper motor during low intake vacuum situations such as when you are going up a hill or accelerating. You can tell which one goes to the wiper motor with the engine running by putting a finger over the lines. The one that sucks on your finger goes to the wipers. If you don't have vacuum wipers don't worry about it. The fuel pump will still work for you.
__________________
Y-Blockhead
  #8 (permalink)
Old 10-24-2009, 08:43 PM
Thanks guys....I just got the 1281 kit from pertronix and need to install it on the other 56......I will hope this is the right one.....will let you know if it is....thanks
Tags
1883 , 292 , 312 , 390 , block , f150 , fe , ford , fuel , pump , pumps , v8 , vacuum , wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
