Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-22-2009, 08:11 PM
DrDaddyDude DrDaddyDude is offline
DrDaddyDude is starting off with a positive reputation.
Pinion bearing
Hey folks, any suggestions are welcome. Have an '01 Exp with a 3.55 Trac-Lok, 192,000 miles. A whine in the pinion bearing started 500 miles ago, it increases/decreases with acceleration/deacceleration, is steady and makes no other noise (clunking, chatter). I changed the gear oil (75-140 with friction add) but no relief. Short of replacing the bearing, would 80-90 gear oil help? Also, any mileage estimates before failure? Thanks.
  #2 (permalink)
Old 10-23-2009, 12:16 AM
alloro alloro is offline
alloro is gaining momentum as a positive member of FTE. alloro is gaining momentum as a positive member of FTE.
Read this thread, but pay attention to the first paragraph of post #8. His pinion nut was loose before he even touched it. This might be the case with you as well. If your's is loose you might be able to simply torque it down to the 160 ft. lbs. and the noise could go away.
http://www.ford-trucks.com/forums/88...-pitfalls.html
__________________
If you like the advice you get, be sure and click the left red "Add to Reputation" button
to the right of the word "permalink" at the top right of the poster's message window.
  #3 (permalink)
Old 10-23-2009, 12:25 AM
Thanks for the reply and the reference to the other post...good info. Appreciate your knowledge.
  #4 (permalink)
Old 11-03-2009, 01:22 PM
Thanks, the pinion nut was overtightened so we backed it off and reset at 160 ft/lbs. Whine was reduced by half or more but is still there.
  #5 (permalink)
Old 11-03-2009, 08:29 PM
Big Greenie Big Greenie is offline
Big Greenie is starting off with a positive reputation.
I would have to guess that all of the bearings in that rear end are worn and loose. Short of a full rebuild, you probably can not eliminate the noise. The pitfall of waiting to do it, assuming you plan to keep the truck for a while, is that when you finally are forced to do it because of a failure, you may have ruined the gearset as well.
It could definately last quite a bit longer as is. The one in my work truck has a little whine and 255,000 miles on it.
__________________
1999 Expedition XLT, big and green, 5.4, 4x4, 285/70-17 Dunlop MT's, factory skid plates, magnaflow muffler.
  #6 (permalink)
Old 11-03-2009, 08:54 PM
Thanks Big Greenie...I plan on keeping it for quite a while and will have work done soon. It's been whining for about 900 miles so the sooner the better.
  #7 (permalink)
Old 11-04-2009, 10:01 AM
Quote:
I wouldn't worry about it. My wife has been whining for the better part of 15 years now and she's showing no sign of quitting anytime soon.
__________________
  #8 (permalink)
Old 11-04-2009, 10:58 AM
Thanks for the laugh, needed it. Glad you're still together. Mine whined for ten years then left me with four kids (her name wasn't Lucille). Had a beautiful '68 Olds 442 and I still say I traded in my 4 speed for 4 kids (they're worth it).
  #9 (permalink)
Old 11-04-2009, 05:39 PM
Damn, some guys get all the luck! I've offered to pack her suitcase and buy her a one-way bus ticket, but she just won't leave.
__________________
  #10 (permalink)
Old 11-04-2009, 10:40 PM
Haaha, good man alloro
Tags
2004 , 2005 , 98 , bearing , bearings , expedition , ford , noise , nut , overtightening , pinion , problems , replacing , truck , whine
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
