where would the o2 sensor be on a 96 f150 4.9l when i get this code. P0147 Heated O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 3)
and heres the other code i got...
P0301 Cylinder #1 Misfire Detected
I'm guessing the I6 has 2 forward sensors on each half of the header and 1 after cat sensor and that's the one you need to investigate, if the fuse is good change the sensor.
ok found the fuse, fuse was good went to autozone got a new sensor. it was original with 200,000 on it. i disconected the battery and we'll see what happens...god i hope this fixes it!!!
