HEEELLLPPP!!!! COMPUTER FRIED?!?!?! NOTHING WORKS!!
Old 02-25-2011, 01:10 AM
1982_f150's Avatar
1982_f150
1982_f150 is offline
Exclamation HEEELLLPPP!!!! COMPUTER FRIED?!?!?! NOTHING WORKS!!
hey, today i parked my 2000 f350 and removed the overhead trip computer to fix it, i broke it in the process so i removed it all together and put the consol back up. i just went to go move the truck closer to a plug (block heater) and the first thing i noticed was the glow plug light did not come on.. surprised me abit, but still fired it up. then.. went to move it, NO gauges worked AND the go pedal does not work!!! replaced the trip comp, nothin.. put my tuner back to stock, nothin.. HELP!!! PLZ
Old 02-25-2011, 01:23 AM
BigAlsPSD's Avatar
BigAlsPSD
BigAlsPSD is offline
No WTS light usually points to a blow fuse for the fuel bowl heater. Unplug it replace fuse and see what happens.
Old 02-25-2011, 01:31 AM
1982_f150's Avatar
1982_f150
wow didnt think one fuse would be connected to so much! scared the ***** outta me, i thought i fried the pcm... thanks! im going to bed now...
Old 02-25-2011, 01:33 AM
BigAlsPSD's Avatar
BigAlsPSD
If thats all it is, it is a common problem, fuse for the fuel bowl heater which are known to short out, is on the same circuit for the PCM. I hope that is all that it is... Most of the time it would not start? Might be an issue with the tuner connections? What type of tuner? Did you hear your fuel pump running?
Old 02-25-2011, 01:36 AM
1982_f150's Avatar
1982_f150
No it still started, its all good now, I must have shorted something out when messing with the trip computer internals today, it's on the same circuit.. I have a superchips cortex tuner..
Old 02-25-2011, 01:38 AM
1982_f150's Avatar
1982_f150
It was Fuse # 19
Old 02-25-2011, 01:41 AM
BigAlsPSD's Avatar
BigAlsPSD
Great to hear, rest easy!
jcee
2004 - 2008 F150
07-30-2012 11:17 PM
livinjeep
22
03-18-2012 03:50 PM
84 f250 6.9
44
05-08-2011 10:50 AM
fordtrck302
09-05-2004 02:20 PM
58 60 f-100
06-23-2004 11:37 PM
Quick Reply: HEEELLLPPP!!!! COMPUTER FRIED?!?!?! NOTHING WORKS!!
