Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #31 (permalink)
Old 10-29-2010, 08:56 PM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is offline
PREMIUM SPONSOR
Garage is empty, add now
Riffraff Performance has a brilliant futureRiffraff Performance has a brilliant futureRiffraff Performance has a brilliant futureRiffraff Performance has a brilliant futureRiffraff Performance has a brilliant futureRiffraff Performance has a brilliant futureRiffraff Performance has a brilliant futureRiffraff Performance has a brilliant futureRiffraff Performance has a brilliant futureRiffraff Performance has a brilliant futureRiffraff Performance has a brilliant future
/pages/Riffraff-Diesel/103160771064 riffraffdiesel
Well put and excellent info Stewart! That is worth a sticky right there...
  #32 (permalink)
Old 10-29-2010, 09:14 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
Support FTE
1999 Ford F-250
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Quote:
Originally Posted by hucka1a View Post
Robin had to replace his injector cups earlier this year.
Actually I replaced the cups thinking I had a problem. After having removed them I don't beleive I did. But since the injectors were coming out anyway new cups with new sealant type went in to be on the safe side. A bad oil cooler o-ring was the problem. Later type oil cooler o-rings make me feel a bit better as well. No coolant in oil and no oil in coolant since the oil cooler R&R. Yes, I'm still running the OAT ELC.
  #33 (permalink)
Old 10-30-2010, 01:18 AM
mongo75's Avatar
mongo75 mongo75 is offline
mongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to all
danny jones
I swapped cups when I rebuilt my block so Icould run ELC, and I use the red stuff from Fleetpride, bottle says it's good for 600k, but i'll probably change it at 500k LOL.
http://fleetpride.com/truck-parts/ca...ges/page22.pdf
__________________
Danny PAA member #12
SoCal Chapter Member
E99 F-350 Dually Van turbo 4x4 CC LB 7.3L, AFE intake, 3 gauge pillar, 4" Magnaflow SS str8-pipe, DP Tuner, Swamps 175/146 SS inj, ARP head and bottom studs, Comp 910 springs, ITP Ovrbst, CCV mod, SS HPX, home made Reg-return, Foil Del, ZooDad, Air Horns 320hp/704tq
  #34 (permalink)
Old 10-30-2010, 07:33 AM
Wayne64SS Wayne64SS is offline
Wayne64SS is starting off with a positive reputation.
Stewart that is excellent info. What coolant would u recommend?
__________________
Later,
Wayne
99 F350 SC LB DRW 7.3 ZF6 4x4
76 Ford F250 4-53t Detroit & Allison AT540
87 Chevy K30 dually 4-53t Detroit swap in progress
  #35 (permalink)
Old 10-30-2010, 07:54 AM
cj45lc's Avatar
cj45lc cj45lc is offline
cj45lc has a very good reputation on FTE.cj45lc has a very good reputation on FTE.cj45lc has a very good reputation on FTE.
If I had a e-99 I would def use the green & add the SCA. Too much PIA IF?
__________________
2000 F250 7.3 Auto SCLB 2WD PHP Tunes AIS 4"TBEXH CCV Mod W-W
  #36 (permalink)
Old 10-30-2010, 11:09 AM
PaysonPSD's Avatar
Support FTE
1999 Ford F-250
Too funny Danny,
  #37 (permalink)
Old 10-30-2010, 02:10 PM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
1999 Ford F-250
My Garage
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
Well, previously, I was always of the mindset that I'd use a HD ELC even if I had an E99, but the past few years I've changed my mind. If I had an E99, I'd use conventional "green" coolant. If I had a L99 or later, I'd flush the block using Gooch's instructions found here http://www.ford-trucks.com/forums/960812-goochs-radiator-engine-backflush-procedure-and-coolant-information.html#post8935201 then I'd refill with Chevron Delo ELC.
That's what I've done to both my Excursion and F250, and I helped Pete do it to his Excursion.
Stewart
__________________
The Brotherhood of FTE <-click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff
2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes
Never Fry Bacon NAKED!
  #38 (permalink)
Old 10-30-2010, 03:49 PM
PaysonPSD's Avatar
Support FTE
1999 Ford F-250
Stewart
"compatibility issues with the older injector cup material, sensors, front cover, seals, gaskets, o-rings, and other stuff, like certain head gaskets that have silicone sealing rings for the coolant flow holes"
I may be on borrowed time Stewart.
I have addressed the cups and and their sealant, the oil cooler o-rings/gaskets and have a new ECT sensor (the only sensor I can think of that comes in contact with the coolant).
Front cover seal, head gaskets and "other stuff", I'll just have to wait and see. If the head gaskets give me a problem it will be a good time to go to head studs while replacing. Leaking front cover and the engine has to come out . . . ouch. I'll do the Melling LPOP then, if not sooner.
Was it OTTOMATIC that has a high mileage E99 that has been running OAT ELC for most of those miles without problems?
  #39 (permalink)
Old 10-30-2010, 03:50 PM
Fat Diesel's Avatar
Fat Diesel Fat Diesel is online now
Fat Diesel has a great reputation on FTE.Fat Diesel has a great reputation on FTE.Fat Diesel has a great reputation on FTE.Fat Diesel has a great reputation on FTE.Fat Diesel has a great reputation on FTE.Fat Diesel has a great reputation on FTE.
Just "went green" again on my latest flush as you know Stewart. I've flushed mine twice now, once at just over 100k and the latest one at over 250k. Injector cups were the deciding factor. Plus it's not a big deal for me to test and add the FW16 as req'd.
__________________
Andy
2012 Race Red Boss 302 "Commuter Car"
Early 99 F250 PSD 4x4 CC 6spd Common Mods 260,000+ Miles, Driven daily like a rented mule
1964 Falcon Convert 289 Toploader 9" 4 Wheel Disks
Nov '10 Recipient: "dedicated report-back tech thread poster" award!
  #40 (permalink)
Old 10-30-2010, 04:10 PM
mongo75's Avatar
danny jones
there's really nothing wrong with the green stuff, I think I only changed to ELC because my engine was in 200 pieces and I was able to swap the cups easy, otherwise nothing looked bad at all, the timing cover and inside of freeze plugs were fine.
__________________
  #41 (permalink)
Old 10-30-2010, 04:42 PM
PaysonPSD's Avatar
Support FTE
1999 Ford F-250
I am sure you are talking about the old engine, which is reassuring.
  #42 (permalink)
Old 10-31-2010, 12:30 PM
hucka1a's Avatar
hucka1a hucka1a is offline
hucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to all
Quote:
Oops, My bad.
Yep, Otto has a lot of miles on OAT.
__________________
Huck
Early 99 F250 with parts from Clay, Scott, Roland, Cory, JD, Pete, Christian, Neal, Jim. You could say "Built by Ford, Modded by the Brotherhood"...
  #43 (permalink)
Old 10-31-2010, 02:06 PM
PaysonPSD's Avatar
Support FTE
1999 Ford F-250
Oops, My bad.
Thanks Huck. I thought it was Otto.
  #44 (permalink)
Old 01-20-2011, 07:00 PM
bockhold's Avatar
bockhold bockhold is offline
bockhold is starting off with a positive reputation.
It's just my opinion, but since Ford didn't make the engines, I go by what International recommends, since they made the engines for Ford.
International recommends an Organic Acid Technology (OAT) Heavy Duty Extended Life Coolant (ELC) for the L99 and up 7.3's, but Ford doesn't.
Ford recommends their "gold" (Zerex G-05 equivalent) Hybrid-Organic Acid Technology (H-OAT) coolant starting with the '02 model year 7.3's.
After much research, International discovered an OAT based coolant doesn't work well and has compatibility issues with the older injector cup material, sensors, front cover, seals, gaskets, o-rings, and other stuff, like certain head gaskets that have silicone sealing rings for the coolant flow holes. To be certain, the problems found with the older type of sealant used during injector cup installation, which doesn't mix well with an OAT ELC, is enough to stop someone in their tracks.
Coolants like ELC's (usually Red) and G-05 (usually Gold) will have these OAT's. Conventional coolants (usually Green) will not.
So, with these incompatibility issues, International revised the necessary components on all 2/2/99-up build engines (SN 940614-up), and began recommending and factory filling with HD ELC coolants mid-year 2000.
GM's Dexcool is an Organic Acid Technology (OAT) coolant, but not all OAT coolants are like what GM uses.
GM typically uses a forumulation which is specifically not recommended for your diesel engine. Dexcool type coolants were absolutely never intended to be used for diesel applications.
There are many modern Heavy Duty Extended Life Coolants specifically designed for diesels. Delo ELC, Rotella ELC, International's Fleetrite ELC, CAT ELC, Mobil 1 ELC, and a host of others.
Compared to conventional "green" coolants, ELC's will address diesel cavitatation protection and provide superior metal corrosion protection, provide better heat transfer, require no testing and maintenance, be free of harmful abrasive silicates, borates, and phosphates, and have an operating life up to 1 million miles (Delo ELC).
Ford's "Gold" (G-05) coolant is nothing like a Heavy Duty ELC coolant, and it will not meet the strict specs required of a HD ELC coolant, or provide the higher level of protection.
The "Gold" is simply a universal hybrid, one-size-fits-all coolant that Ford uses in its entire line up that, with the exception of the Powerstroke, are all gasoline engines. Ford simply uses the "Gold" in the 7.3L PSD out of convenience, simplicity, cost, and uniformity throughout it's product line and dealerships.
The "Gold" coolant contains conventional "green" coolant components, like silicates, which eventually form microscopic abrasives that eat water pump seals. The "Gold" provides a lower level of cavitation protection using traditional SCA's like nitrite, it has a shorter life, it's not as effective as an ELC at heat transfer, and in some applications, requires testing and SCA maintenance (just like the conventional "green" coolant) if you are an enthusiast about protecting your engine.
In fact, Ford recommends you add SCA's to the "Gold" in certain F-Series applications. Caterpillar and John Deere also recommend adding SCA if it is going to be used in their diesels.
Ford's H-OAT "Gold" coolant will not meet International's heavy duty diesel B-1 specification. A Heavy Duty ELC will.
The "Gold" will work, but it's not the best.
Stewart
  #45 (permalink)
Old 01-21-2011, 01:03 AM
justblowin'smoke justblowin'smoke is offline
justblowin'smoke is starting off with a positive reputation.
check into fleetguard cc2826 coolant. the company i work for switched to this 2yrs ago from elc coolant it seems pretty good. i would still test the coolant and if you have a coolant filter run one with additve in it already and change it every year
__________________
Nick early 99 F350 XLT 6sp 4x4 7.3L mods 5" stacks, 4" dp, autometer guages, dp tuner 60t, 80t, 80 econ, 120r 140 smoke and K&N cold air intake with afe pro guard filter, southbend 550hp clutch, turbonetics ball bearing turbo, updated to late turbo set up, BD exhaust brake
Tags
1999, 73, 73psd, antifreeze, brand, converting, cool, coolant, coolent, diesel, early, elc, f250, ford, model, power, powerstroke, recommended
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
