Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-22-2009, 05:09 PM
Terrell460 Terrell460 is offline
Terrell460 is starting off with a positive reputation.
460 EFI build
I have a 1990 Ford F250 with a fuel injected 460. Im planing on rebuilding the engine with performance parts and turbo charging it. I want to update the old fuel injection with a new ECU that i can program for different situations. I was thinking of going with an XFI unit from FAST. anyone have any experience with XFI or any other performance ECU's? i would apreciate any advice.
  #2 (permalink)
Old 11-02-2009, 03:12 AM
fordsinair fordsinair is offline
fordsinair is starting off with a positive reputation.
I'm doing something along the same lines. I have a 78 460 in carbueretor form right now. My friend and I are contemplating a system from Megasquirt. But using a carb blow threw set up is still in consideration. We're searching out info for the easiest route to go. Cost really isn't a concern. Tuneability and set-up are the biggest concerns right now. The plan is a mid-sized turbo for street/strip use. We are thinking 700-800 Hp isn't that hard to do.
After doing some research I'd like to hear/see how a 460 performs, idling and part throttle, with the Jon Kaase P-51 aluminum heads. Jon built a mostly stock engine with his heads and a big solid lifter cam and made 690hp--Dang! Scroll down to "Ford Power Test" and read from there.
Jon Kaase Racing Engines - Kaase P-51 - Big Block Ford Wedge Cylinder Heads
Like I said I'm still researching what I'd want from the engine. I think with a mid sized turbo the engine might behave better under cruising conditions on the street. Not sure though.
  #3 (permalink)
Old 11-04-2009, 01:54 AM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE. Bear 45/70 has a good reputation on FTE.
The trouble with your plan is that the 460's EFI system just does respond well to hot rodding.
__________________
Bear 45/70 Gimp Racing <a href=http://i145.photobucket.com/albums/r206/Bear-45-70/Emoticons/icon_weelchairbb.gif target=_blank>http://i145.photobucket.com/albums/r...eelchairbb.gif</a>
“There are only two things stopping you, common sense and fear! And not much of the latter.”
  #4 (permalink)
Old 11-04-2009, 11:56 PM
capn kirk capn kirk is offline
capn kirk is starting off with a positive reputation.
mass air conversion could be the ticket or with the ecu your talking about running just tuning it could be fine
__________________
1996 F-250 460 Super Cab 8' Bed 4x4
3.55 limited slip frnt/rear, 37x12.50 Goodyear Military OZ, 4" Skyjacker, 3" body lift, hedman headers 3" single-back turndown before rear axle, K&N Air Filter, deep tranny pan, Warn hub kit, Alpine 9857 Head Unit, Alpine S-Type frnt spkrs, Sony 6"x9"s (in mobile boxes),flip-down gooseneck ball--to come--gears, cam, port heads
  #5 (permalink)
Old 11-14-2009, 11:20 PM
stngh8r stngh8r is offline
stngh8r is starting off with a positive reputation.
Smile
Quote:
-I agree. However, with the stand alone systems mentioned, Terrell460 shouldn't have anything holding him back.
-Terrell460, I like your plan. I actually purchased a turbo about two years ago with big plans. Unfortunately, due to finances, that is as far as it has gotten.
-My plan included megasquirt for tuning. I should think any of the stand alone offerings would work though.
-Check out the turbo forums dot com as an excellent source of turbo info
-Good luck and keep us posted.
Happy Modding
Eric
__________________
1990 F250 EC 460/E40D/3.55s | 3.5" straight pipe | NA = 220rwhp/360tq | 50shot N2O = 264rwhp/415tq | 1/8 mile 9.9 w/2.2 60ft
Tags
1990 , 460 , 460efi , 89 , camshaft , cylinder , efi , foed , ford , fuel , heads , injected , injection , performance , specs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
