Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-22-2009, 10:53 AM
fordbedflat fordbedflat is offline
1954 Ford F-100
fordbedflat is starting off with a positive reputation.
Question 239 for 312 Engine swap
Was advised to ask question here. I have a running 239 w/ 3spd overdrive out of a 55 effie and I want to put in a 57 wagon I recently purchased that has a worn out 312 and fordomatic.. How difficult would it be to swap in the 239 and leave the fordomatic and what would have to be changed? Money permitting I'll eventually put the 312 back in. Thanks for the replies.
  #2 (permalink)
Old 10-22-2009, 02:06 PM
HT32BSX115's Avatar
HT32BSX115 HT32BSX115 is offline
HT32BSX115 is starting off with a positive reputation.
Howdy,
The 239 should bolt right up to the Fordomatic. I'm pretty sure you will have to use the starter and flexplate that is currently on the 312.
You can also go to http://www.y-blocksforever.com/forums/Forum3-1.aspx for a lot of info on this..
Cheers,
Rick
__________________
1955 F-600 // D I S C L A I M E R: No animals were injured while test driving my F-600 except the ones I RAN OVER INTENTIONALLY!!! (RESISTANCE IS FUTILE) 73 de Rick
  #3 (permalink)
Old 10-23-2009, 01:57 AM
1954 Ford F-100
Thanks for the info and website Rick!
Happy Motoring,
Brian
  #4 (permalink)
Old 10-23-2009, 06:59 AM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is starting off with a positive reputation.
After the 57 is running wth the 239, you will probably have more incentive to get the 312 rebuilt .
__________________
COLOR=Navy]1946 1/2 ton with Y-block
1964 F-250, 292 4 speeed
1990 Ranger 4WD
  #5 (permalink)
Old 11-01-2009, 07:13 PM
1954 Ford F-100
Wink 239 for 312 engine swap
Quote:
Your right! I pulled the 312 out last week and I'm going to rebuild it..For now the 239 will remain in the F-100.
Brian
  #6 (permalink)
Old 11-02-2009, 06:49 AM
46yblock's Avatar
Quote:
Brian
That sounds like a good plan. Hope the 312 is in fairly good shape. I've recently gained more respect for the 312s. For instance didnt know they have a narrower top compression ring, givng less power loss due to parasitic friction. Also John Mummert told me a 292 piston will result in skirt interference used with the 312 crank.
FYI, it is looking good for the use of an Eagle SBC 6.250 rod, with an offset ground 312 crank rod journal allowing the use of a 2.1 in. journal on the Eagle rod. All while using a 312 piston moded to take an SBC piston pin. The guys at y-blocksforever have been helping me wade through the process. Result would be a 312 with stroke increased from 3.44 to 3.50, and the ability to achieve zero deck (top of piston even with deck) without removal of a large portion of the block deck. Plus the Eagle rod is new and stronger than the original, at a cost equal to that of rebuilding the originals. I will know later today if the plan is a go.
Best of luck. Keep us updated.
__________________
1990 Ranger 4WD
  #7 (permalink)
Old 11-15-2009, 07:03 AM
Fifty4F100's Avatar
Fifty4F100 Fifty4F100 is offline
Fifty4F100 is gaining momentum as a positive member of FTE.
I know I'm late coming into this conversation. I think that just for 54, the 239 was made in Dearborn and Cleveland. The 2 were not interchangable. I don't know if the bellhousing mounts would be that different, but I would check.
And yes the 239 is a dog. Just over 100 HP that weighs within 10# of a 460!
__________________
Glenn in TN
02 F350 Supercrew Long Bed SRW Lariat 7.3 PSD (Finally diesel for around $2.50/gallon)
99 Chevy C1500 Ext. Cab
54 F100
Tags
1954 , 1955 , 54 , bolt , engine , flexplate , ford , fordomatic , swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
