Go Back   Ford Truck Enthusiasts Forums > Diesel > 2008 - 2010 6.4L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2008 - 2010 6.4L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 10-29-2009, 08:19 PM
duallydan duallydan is offline
duallydan is starting off with a positive reputation.
Quote:
Originally Posted by sdetweil View Post
where do you have info on the gear vendors OD for these?
Sam
I thought it was on their webpage. A ford 5 speed tranny. Was going to call and clarify a few things regarding towing weights, etc.
  #17 (permalink)
Old 11-03-2009, 08:07 PM
cp101 cp101 is offline
cp101 is starting off with a positive reputation.
My $.02 . . . .
I've been trying dozens of different "non'tuner" ways to improve mileage over the past 12,000 miles. Here's the best thing I've figured out:
You can (and must) reduce the amount of DPF regen time to a minimum. Here are 2 ways you can do that:
1) - If you are mostly driving around town, try getting your truck on the highway for about a 20 minute uninterrupted run every 3 or 4 days. This will actually help delay the start of the next regen. You end up with far fewer regens per month if you do this.
2) - Once a regen cycle starts, DO NOT shut off your truck until the cycle completes. If you shut down before the cycle ends completely, another FULL regen cycle will initiate the next time you start the engine.
This works for me. I hope it also works for any of you who try it. Good luck.
  #18 (permalink)
Old 11-03-2009, 11:27 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
1993 Ford F-250
FORDF250HDXLT is starting off with a positive reputation.
i hate that regen cycle.
been borrowing my dads truck while im between trucks.
the dang thing comes on way to often killing fuel mileage.
if it where my truck,that would be bypassed asap!
according to the built in mpg gauge-who knows how accurate that is,
it generally says 12-13 working with a load on regularly.
not outstanding.but the thing has gobs of power.impressive.
f350 reg cab.-looked up the gears,but forgot them now sorry.
__________________
1993 F250 Heavy Duty 4x4 XLT, regular cab, two tone with red interior, 444CID/IDI/NA International Diesel, E40D auto, 1356 BW manual shift TC, Dana 50 TTB front/Ford-Sterling 10.25 2nd-gen full floater rear with 3.55:1 gears.That's stock.See my garage for mods. 47k original miles. Carfax clean w/last OR 29,200 in '06. Not yet on the road. Brand-new to me.
Real Trucks Don't Have Spark Plugs.
  #19 (permalink)
Old 11-04-2009, 07:27 AM
Without exageration, the regen cycle yesterday started with my fuel gauge at 1/4 and finished at 1/8 . . . . an eigth of a tank gone in 20 minutes! This is insanity at $3 a gallon !!!
  #20 (permalink)
Old 11-10-2009, 02:44 PM
Papi4baby's Avatar
Papi4baby Papi4baby is offline
Papi4baby is starting off with a positive reputation.
I got my truck about a month ago.
I am at around 1100 miles. The computer displays 13.6. I put fuel yesterday and by my calculations i got 14.5. I drive 50mi round trip to and from work empty. And it's about 85/90% highway the fastest i'll go is 65. My speed is between 50 and 65 most of the trip. And i have yet to get a regen, well at least i have not seen a warning for it.
Edit, for extra info.
2010 F250 crew with 8' bed 4x4.
  #21 (permalink)
Old 11-11-2009, 09:01 AM
richfaa richfaa is offline
richfaa is starting off with a positive reputation.
There is something seriously wrong with your truck unless you ae doing 80/90MPH during that time. We will drop 2/3 mpg during a regen.
__________________
..F-350 6.,CC,LB, 4X4 off road, dually, camper package, snow plow package. 4:10LS. Uswed to tow a 14K plus 5th wheel.
  #22 (permalink)
Old 11-11-2009, 10:23 AM
Crazy001's Avatar
Crazy001 Crazy001 is offline
2008 Ford F-250
Crazy001 has a good reputation on FTE. Crazy001 has a good reputation on FTE.
Have you ever heard of the saying "stepping over dollars to save pennies?" That 20 minute highway cruise will burn an additional 1-2 gallons of fuel that you don't need to burn. That dreaded regen cycle is awfully inefficient, there's no debate there. But even if you cut your regens in half, which isn't likely, you will NOT recoup the fuel you burn during your highway run. On the highway my truck seems to regen every 250-300 miles. I also have gotten as high as 17 MPG before on the highway, but I don't drive it like most people my age do.
Also, you're partially right about your second point. It is more efficient to let the engine do it's thing, but the regen cycles aren't timed or preset. It all revolves around the exhaust backpressure sensors and the way your PCM interprets their signals. One time I went into regen 5 minutes before I shut it down, and I didn't see another regen for over 100 miles. Other times I shut it off during regen and it starts immediately the next time the engine coolant gets over 164 degrees.
If I have more than a few days of not driving long enough to complete then I will get on the highway to clean it all out. Otherwise I just drive it normally.
__________________
Tom,
Current truck - 2008 F250 CC 4x4 PSD
Previous Fords:
2007 F150 Screw 4x4
2003 F150 4x4 r/c auto
  #23 (permalink)
Old 11-14-2009, 03:45 PM
Quote:
Originally Posted by duallydan View Post
I just towed my 36 foot car hauler halfway across Canada. Weighed in at about 32,000lbs total. Pulled like a mother. Averaged 6.5 mpg.
I drive a '08 f450 6.4 with the 4.88 rear end. That is the worst combo you can even dream of for mileage.
Just ordered up a bunch of goodies from Cobbs, H &S Tuner, going to straight pipe it, EGR delete plates, CFM intake elbow, cold air, and a intercooler pipe to replace the mashed one through the rad support.
Wanted to give you some REAL numbers on mileage and an update. Just did another 1000 mile round trip. Did the first half stock, and the second half with the dpf delete, h & s blackmaxx, and a cold air intake.
On the first half, averaged 10 miles per gallon (empty and hand calculated), on the way home (same roads, same speeds) averaged 15 miles per gallon.
This is an f450, 4.88 gears. ran at about 60 miles per hour the whole time.
My advice to everyone looking for mileage, get a tuner, ditch the dpf, and get an air intake....just do it.
  #24 (permalink)
Old 11-17-2009, 12:18 PM
cyrzee cyrzee is offline
cyrzee is starting off with a positive reputation.
Fuel Mileage
I am looking for a little feed back on the 2008 F350 powerstroke. I have been told the fuel consumption is brutal on the 2008 powerstrokes?? I have come across a 2008 F350 King Ranch with approx. 10,000 miles on it. The low mileage makes me wonder why it is for sale so soon?? Any feed back would be great.
Cyrzee
  #25 (permalink)
Old 11-17-2009, 01:04 PM
R-T0r21on R-T0r21on is offline
2008 Ford F-350
R-T0r21on is starting off with a positive reputation.
Just ask the dealer as many questions as you can about the truck, for instance; Was it a buy back? Is it a job #1,2,or 3? What has it had done there by the dealership? They must provide full disclosure. Ask for the Oasis report. You might even be able to find something on Carfax.com. Fuel mileage varies greatly depending on driving habits, terrain, gear ratios, etc.
These are really great trucks with lots of towing power. The EPA mandated a lot of crap that suffocates these beasts though. Good luck. Hope this helps some...
__________________
Job #1 F-350 SRW, 6.4 PSD, Auto, 4x4, supercab, long bed, Line-X, Vent visors, AFE cold air intake, MBRP "cool duals" exhaust, Bed locker electric retractable tonneau cover, Kenwood DNX-1820 Nav./ stereo w/ backup camera, Spartan 275 hp DOC/DPF delete tune.
  #26 (permalink)
Old 11-17-2009, 09:20 PM
StanleyZ's Avatar
StanleyZ StanleyZ is offline
SHADE TREEIN SINCE 1957
StanleyZ is gaining momentum as a positive member of FTE.
Quote:
Cyrzee
Cyrzee, your not. You are wise to think about fuel mileage. It is awlful, more so for some, like those with DRWs or the 4.30 rear axle or the 4.10 rear axle a combination of the three. And most of all those with a heavy foot. If you can afford the fuel though it will pull a freight train up a hill. If you're gonna tow and its a DRW with a 4.10 or 4.30 expect 8 to 9 MPG. You might get it up a little by not using cruise but I wouldn't expect it. If you drive in town maybe 12 to 13 for that truck, some better for a SRW or a 3.73 rear. highway towing empty is not a lot better. Now if you're willing to modify the truck which will almost surely void the warranty there are folks on here who swear it will increase all those numbers significantly. BTW, I bought an 08 in may with 4000 on it. The guy had two other 6.4s and his fuel bill had to be killing him.
__________________
2008 F350 DRW Lariat/ 4.30 Diff/Titan 60 Gal fuel tank/Bone stock running gear and just a little truck bling.
  #27 (permalink)
Old 11-18-2009, 12:39 AM
Quote:
Try 4.88's in a f450. I got 10 mpg empty, and 6 with a full load (32,000 lbs total)... After I put in an H&S blackmax, straight pipe, and air intake I got 15mpg empty. Hand calculated, no bull****.
  #28 (permalink)
Old 11-18-2009, 09:15 AM
Thanks for the feedback guys.
Cyrzee
  #29 (permalink)
Old 11-18-2009, 09:39 AM
percyad's Avatar
percyad percyad is offline
percyad is starting off with a positive reputation.
Thumbs up Does Cetane Booster Help Reduce Frequency of Regen?
Guys, now that I've had my '08 F250 6.4L for six months, I've noticed a pattern that regular use of DieselKlean additive or other cetane booster has dramatically reduced the frequency of exhaust cleaning/regen cycles. Before regular use of the additive, I was averaging a cycle every 250 miles. Now I regularly go past 600 miles before a cycle.
If the additives are improving combustion and reducing soot, that would lead to fewer cleaning cycles, correct?
Anyone else have a similar experience?
BTW: the additives are not cheap, in my case they are paying for themselves.
  #30 (permalink)
Old 11-18-2009, 04:52 PM
Crazy001's Avatar
2008 Ford F-250
Quote:
Diesel Kleen IS cheap! It works out to somewhere around $2.00 a tank.
And you're right about it paying for itself, I've noticed my truck run better and get better MPGs with the use of additive.
I can't comment on the frequency of regens because I started using Diesel Kleen with 400 miles on the odometer, starting my second tank of fuel.
__________________
Tom,
Previous Fords:
2007 F150 Screw 4x4
Tags
2001 , 2009 , 350 , chaplin , ct , diesel , f250 , f350 , ford , fuel , fuelmilage , fule , milage , performance , street , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
