Unless they have changed something in the newer Escape/brakes, they are quite simple.
- Remove the tire & rim
- Remove the brake caliper clip
- Remove the caliper bolt caps & the bolts
- R & R the pads
- Install in reverse order
There is nothing for "special" tools required. I cannot remember the size, but all you need is an allen key or allen-type socket.
