Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-22-2009, 07:34 AM
shailey shailey is offline
shailey is starting off with a positive reputation.
2006 F150 Hot Transmission Fluid
Folks,
I'm looking at a 2006 F150 for purchase. It's a XL Style with the 4.6L and long bed. I test drove it for about 15 minutes at 70 mph yesterday. Afterwords, I pulled the automatic transmission dipstick to smell the transmission fluid and was surprised to find that the dipstick was hot.
How hot should the transmission fluid normally be? I guess that the temp was about 140-150 degrees F - I could touch the end of the dipstick that was immersed in the transmission fluid, but could not hold it without pain. The transmission seemed to operate fine otherwise. The fluid smelled normal - no "burnt" smell.
Please let me know if this is normal. Should I pass on this one?
Steve
  #2 (permalink)
Old 10-23-2009, 08:22 AM
l-m tech l-m tech is offline
l-m tech is gaining momentum as a positive member of FTE.
most temps ive monitored with my scanner are between 140-175.
__________________
ASE MASTER TECH FORD SENIOR MASTER TECH
  #3 (permalink)
Old 10-28-2009, 04:11 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of
Well the engine runs about 195* so the transmission will run close to that in the range mentioned above.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
Tags
06 , 2006 , 2008 , 2009 , add , atf , change , f150 , fluid , flush , ford , problems , trans , transmission , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
