Go Back   Ford Truck Enthusiasts Forums > General > Garage and Workshop
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Garage and Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Is F-150 Still King?
  #1 (permalink)
Old 10-22-2009, 01:36 AM
havi's Avatar
havi havi is offline
Collector of rust
havi is gaining momentum as a positive member of FTE. havi is gaining momentum as a positive member of FTE.
Best floor jacks for the money?
As the title says. I was looking at the AC DK20HLQ low profile floor jack, and as much as I would love to have something like that, 2 things come into play:
1) One truck I have is a 2 ton, and would need something heavy duty, but the others are lowered.
2) Even the AC I listed is about $850.
Anyone have a similar alternative to recommend?
My old Chinese 3 ton is about toast. And not to mention, my back ain't like it used to be, so carrying one out to the back 40 has become a chore.
Thanks.
__________________
I lack focus. That, and I lack focus.
1948 F1
1950 F6
1978 F150 4x4
several others for parts
Also looking for a 1937 Ford sedan 2dr, and any old panel truck.
  #2 (permalink)
Old 10-22-2009, 02:42 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of
A used Lincoln works pretty well, check the Craigslist for your area. I picked up a pair of Lincoln 3tons medium frame jacks for $30 a couple years back, and traded one off for some tires for my truck. The deals are there if you look and are patient.
__________________
Jared
The government said all my vehicle were too old to be clunkers
FTE Guidelines
  #3 (permalink)
Old 10-22-2009, 10:16 PM
havi's Avatar
Collector of rust
I can be patient, lol. I guess it's kinda leaning towards one long-jack, like the Lincoln, and one aluminum lightweight for the out-in-the-yard needs.
__________________
1948 F1
1950 F6
1978 F150 4x4
  #4 (permalink)
Old 10-22-2009, 10:41 PM
thecardoc thecardoc is offline
thecardoc is starting off with a positive reputation.
Check out Harbor Freight. I think I saw a low profile aluminum one for about $89.00
  #5 (permalink)
Old 10-22-2009, 10:55 PM
MisterCMK's Avatar
MisterCMK MisterCMK is offline
1994 Ford Mustang
My Garage
MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold
I've got a Michelin brand jack that I picked up from Sams Club. It is quick going up without anything on it and will lift 3 1/2 tons or something like that.
__________________
Chris
1994 Mustang GT
1992 Explorer XLT
2000 Expedition EB
http://mistercmk.com/images/sig.jpg
Quote:
Originally Posted by tcbofade
I have no brain
  #6 (permalink)
Old 10-23-2009, 07:31 AM
mitchntx's Avatar
mitchntx mitchntx is offline
mitchntx is starting off with a positive reputation.
Quote:
I bought DK13HLQ over 10 years ago. Works today just like it did the day it arrived ... and I use the crap out of it. Best money I have ever spent.
My 13 won't lift my old GMC HD, my Bronco or my PSD SD ... not even a single tire off the ground.
These are quality tools and will outlast any vehicle you own.
According to this site ...
http://www.asedeals.com/hydraulicjacks2.html
they are no longer available through them. Not sure if its a supplier issue or a manufacturing issue. Either way, I wouldn't hesitate buying on of these guys.
__________________
96 CMC Firebird
05 DL 1000 V-Strom
07 F250 Lariat 4x4 SD
  #7 (permalink)
Old 10-23-2009, 11:38 AM
Mr.Ford 351W's Avatar
Mr.Ford 351W Mr.Ford 351W is offline
Mr.Ford 351W is starting off with a positive reputation.
Napa has a jack for 136 bucks,it is a 2 1/4 ton jack
__________________
There is no stupid question,but if you ask it more than once ,you are the stupid person!!
  #8 (permalink)
Old 10-23-2009, 08:32 PM
Phinxter Phinxter is offline
Phinxter is starting off with a positive reputation.
Quote:
I bought one of those a few years ago and haven't used it much. Now it refuses to lift anything. found some oil under it so I added some and bled it it worked ok at first but then crapped out again, not sure if it would be worth it to have it fixed. I paid like $60 My POS HF jack that is older still works and I use it alot more.
__________________
Phinxter
1977 Ford F-100 Custom Rustbucket
1993 Plymouth Sundance
2009 Saturn Aura
ASE Master Recertified Automotive Tech
  #9 (permalink)
Old 10-23-2009, 09:19 PM
*2fords* *2fords* is offline
*2fords* is starting off with a positive reputation.
I had one of those Michelin jacks til some stole it and my Hi lift jack right off my deck. I can't find another one anywhere, apparently no one sells them any more.
Every HF jack I have had, has turned out to be a POS. From the one on my press to the one on my Cherry picker mounted on my flat bed, the seals go out and I can't find an O ring for any of them that will fit.
__________________
92 F-150 flairside all stock 5.0 auto 2WD
93 F-250 4x4 flatbed 5.8 auto KnN, throttle body spacer, underdrive pulleys, flowmaster
73 Jeep CJ5 springover axles, reversed front shackles, 304, T-18, lockers front/rear, 4:29 gears, 33s
87 Toyota Tercel Tuner some engine mods exhaust
  #10 (permalink)
Old 10-23-2009, 10:25 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a good reputation on FTE. ctubutis has a good reputation on FTE.
Harbor Freight == The Home of Inexpensive, Single-Use, Chinese-Made Tools
  #11 (permalink)
Old 10-24-2009, 11:14 AM
My HF jack came with an extra set of seals. Angle grinder came with extra brushes.
__________________
Phinxter
2009 Saturn Aura
  #12 (permalink)
Old 10-24-2009, 04:41 PM
dstig1 dstig1 is offline
dstig1 is gaining momentum as a positive member of FTE.
I got this jack from Northern a year ago and it is sweet. Very smooth action on jack and release and it is very low profile. It is made in China, but it seems very well designed and made. Only $150 and it lifts everything from my ground hugging POS civic to my SD.
The packaging was insufficient as the package was very torn up upon arrival, but the jack was undamaged. It weighs a flippin' ton too.
Arcan Quick Lift Service Jack — 3 1/2-Ton, Model# XL35 | Floor Jacks | Northern Tool + Equipment
-Dave
__________________
- Dave
2005 F250 Lariat SuperCab Long Box 5.4 Auto 4x4
1999 Explorer AWD 5.0 4-door
  #13 (permalink)
Old 10-24-2009, 05:56 PM
gfw1985's Avatar
gfw1985 gfw1985 is offline
gfw1985 is starting off with a positive reputation.
One more bad feedback on the Michelin. Friend gave it to me because it quit working, only used a couple times. Can't even find any info on how to even fix it. Saved the handle for a cheater bar. Is a nice handle, rest is junk.
__________________
76 Bronco Explorer 289 Hi-Po
66 Bronco Half Cab 203ci I6, CI aluminum head and intake, Isky 256/256 cam, Keith Black pistons, Clifford header, Holley 390cfm 4v, 9.7:1 comp. 4:11 gears-3 speed
  #14 (permalink)
Old 10-25-2009, 12:25 AM
havi's Avatar
Collector of rust
There's a Northern Tool nearby, I may have to look at that Arcan. Should tie me over for the while, thanks.
Thanks to the rest of ya, too.
There's a used Blackhawk 4 ton in the local CL for $200, but it looks pretty beat up. (50 years old?) Something like that should be had for about $50. I don't need to lift my big truck until next Spring or so anyway, so hopefully something comes along this Winter, lol. Besides, I have a 20 ton bottle jack if needed.
__________________
1948 F1
1950 F6
1978 F150 4x4
  #15 (permalink)
Old 10-25-2009, 12:45 PM
If you try Northern, make sure it is one of the new big stores (Minnetonka and one other?) Otherwise, I think this jack might be mail order only, and even the big stores might not have it on the floor. I was wary getting it sight unseen but have been very impressed.
__________________
- Dave
Tags
2006 , ac , craigslist , dk20hlq , duty , f250 , find , floor , ford , heavy , jack , jacks , locate , michelin , michilem , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
