Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-22-2009, 01:13 AM
keisha9 keisha9 is offline
keisha9 is starting off with a positive reputation.
fuel taking a long time to get to 390
when cold my truck takes a while about 20 seconds of cranking before it will start . after this it fires right up .. does anyone know why its taking so long ? could my furl line be too thick .. or could i need a electric furl pump so that the furl is always "right there" at the carb?
  #2 (permalink)
Old 10-22-2009, 02:13 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
"Cold"? How cold? Choke working? What do you have for ignition?
  #3 (permalink)
Old 10-22-2009, 12:56 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
Also, are you pumping the pedal a few times BEFORE you crank it to set the choke and pump some gas into the intake?
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #4 (permalink)
Old 10-22-2009, 06:07 PM
the choke works and it is manual choke. the edelbrock carb is new. when i say cold i mean if i dont drive it for a week and try to start it then it does this. if i drive everyday then it works normal.
  #5 (permalink)
Old 10-22-2009, 06:08 PM
oh yea I pump it alot trying to get the fuel up there. you know what? F this im going out there right now and i'm going to find my problem . me and muddy buddy weizer that is ..ill let you guys know if i find anything but comments are still welcome
  #6 (permalink)
Old 10-22-2009, 06:25 PM
Krewat's Avatar
After waiting the amount of time it would usually take for this to happen (a week), take off the fuel line from the carb, put the end into a bucket or big jar, and crank. See if it's really not getting fuel, or something else is going on.
Maybe the fuel pump valves are leaking, and the fuel siphons all the way back to the tank? Or there's some air leak somewhere that you don't know about?
__________________
  #7 (permalink)
Old 10-25-2009, 12:04 AM
Kennewick's Avatar
Kennewick Kennewick is offline
Kennewick is starting off with a positive reputation.
Could it be leaking out of the bowl? I had that peoblem, it was leaking out the accell pump right onto the mani. Took about a day for it drain down.
  #8 (permalink)
Old 10-25-2009, 10:22 AM
i have msd ignition..i am waiting a week then will pull the fuel line off the carb and see if fuel is present. if not then i will investigate the bowl of the carb leaking.. thanks . what did u do kennewick to fix your problem?
  #9 (permalink)
Old 10-25-2009, 12:09 PM
Kennewick's Avatar
Quote:
You can buy the accellerator pump parts from any parts house. I assume you have a Autolite 2100 but that is something you will need to know. There is the possibility you may need to do a complete rebuild. The Autolites are easy to rebuild. If you do you need to, pay attention to the ventury shaft as they get loose in the bore. A machinist can punch the hole and insert a bushing restoring it to spec.
Good luck my guess is you don't have a huge problem, just take your time school yourself and have fun.
PS there is a small check valve(looks like a small rubber plug, becareful as if you pull on it it could just break in half. If you pull the carb top you can see where it penetrates through it's bore) also there is a diaphram which is where your leak could be comming from, There is a spring pay attention to direction and a gasket. Mine leaked right through the diaphram right out of the housing through the little weep hole onto the manifold a drip at a time till empty.
  #10 (permalink)
Old 10-25-2009, 04:11 PM
i'm running an edelbrock 750 and its fairly new but i will still check that out too
  #11 (permalink)
Old 10-25-2009, 04:43 PM
Kennewick's Avatar
Thats a lot of carb what are your motor specs? I was thinking stock.....Not!
This is on the 56 right? You just list a 390. Great project though. My Brother had a 56 with a nice 302. White with a touch of brown in it to take the bite out of the white and bronzed windows. Nice trucks.
  #12 (permalink)
Old 10-25-2009, 09:08 PM
yea, well its actually a 360 but 1 day a 390. edel intake , headers, msd ignition. other than that its stock 360.
  #13 (permalink)
Old 10-25-2009, 10:09 PM
Argess Argess is offline
Argess is starting off with a positive reputation.
I have the same problem.....if I let it sit for more than a few days, it cranks a fair bit. I don't have a choke hooked up, but a few pumps and it always catches.....unless I leave it more than 2 or 3 days. Then it takes a lot of gas pedal pumping.
I do know that sometimes the fuel line drains back into the tank, so the fuel pump one-way valves arn't doing % of their job, but I can assure you, the pump can fill up the line and carb float bowls very quickly. Besides, I'm also quite sure my float bowls are still (mostly) full.
I suspect fuel in the intake manifold has evaporated out and the accel pump galleries have siphoned dry (back to the fuel bowls). Intake drying out due to exposed airfilters and accel pump drying out as I have Holleys and there isn't much to stop a reverse siphon...at least to the level in the bowls.
If you solve your problem, I hope you will post the solution.
  #14 (permalink)
Old 10-25-2009, 11:36 PM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE. Bear 45/70 has a good reputation on FTE.
This sounds more like fuel draining back to the tank thru the fuel pump, indicating the valves in the pump are not sealing properly. The carb going dry is no big deal if the fuel line is full up to the carb. The pump will fill the carb in just a couple of revolutions. If the line drains dry clear back to the tank, then the pump has to suck fuel from the tank before the carb gets it. Fuel pumps don't suck and pump air worth a damn.
__________________
Bear 45/70
Gimp Racing
<a href=http://i145.photobucket.com/albums/r206/Bear-45-70/Emoticons/icon_weelchairbb.gif target=_blank>http://i145.photobucket.com/albums/r...eelchairbb.gif</a>
  #15 (permalink)
Old 10-26-2009, 02:07 PM
Kennewick's Avatar
Not that it is any of my business but that is alot of carb for a stock 360. Does it drive good? Just curious.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
