Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #31 (permalink)
Old 10-29-2009, 11:34 PM
Kennewick's Avatar
Kennewick Kennewick is offline
Kennewick is starting off with a positive reputation.
So K9 I didn't mean to NUKE your thread "LOL" but what did you come up with?
I should be getting my truck back together soon and I will post my new intake, carb, and induction mods with some pic's since your running a 360 like me. I was working on my new cold air design in my lab today and that is getting better My first 2 attempts worked but not as good as I wanted plus they were butt ugly in my oppinion. This new one will floww better and act almost like ram air going down the highway. Here is the last ones.
  #32 (permalink)
Old 10-31-2009, 09:30 PM
keisha9 keisha9 is offline
keisha9 is starting off with a positive reputation.
well it has been a week but i havent wanted to start it yet because im affraid that it hasnt taken its whole effect yet. but i think i will go out there tomorrow and see whats going on with the fuel leak from either the bowls or the diaphram in the pump. BTW ...kennewick nice airram!
  #33 (permalink)
Old 11-01-2009, 12:44 AM
Kennewick's Avatar
Look at my new post on ram air my new one is way better.
  #34 (permalink)
Old 11-01-2009, 05:15 PM
well turns out that the Fuel Pump is pumping right away so thats good. it also appears that when i pumped my throttle linkage i only got about 2.5 pumps before no more gas was spraying into the body then it was dry. i'm guessing that there should be more gas in the bowl and that it is leaking? i say this because after i got the 2 pumps i started the motor , turned it off, then pumped it and looked into the body and i got 7,8,9 pumps of gas to spray right after the engine had been started. my edelbrock carb is fairly new and i cant see why it would leak! any suggestions?
  #35 (permalink)
Old 11-01-2009, 06:25 PM
Kennewick's Avatar
Have you checked your oil level to see if you are draining into your oil pan. It's not a good thing!! perhaps leaking past your needle and seat. I would think you could drain from the fuel line untill the pressure is gone. That could flood some through the carb filling the bowl. Then you get a couple of squirts out of the bowl but the fuel line is mostly empty. When you start the pump pumps it right up after a couple of turns of the crank and everything seems normal. But watch you oil level and see if it is high.
Just thinking.
  #36 (permalink)
Old 11-03-2009, 11:30 PM
Kennewick's Avatar
What did you find?
  #37 (permalink)
Old 11-04-2009, 08:27 PM
how would it go in to the oilpan?
  #38 (permalink)
Old 11-04-2009, 09:44 PM
Kennewick's Avatar
Well if you took a gallon of fuel thats in a gas can and started to pour it through the carb until it was empty where do you think it would end up?
So I was wondering if you could be leaking fuel down through the carb. It has to be going somewhere. If it ends up in your oil you get a condition called gasoil. It's not a good lubricant. It has killed many a motorcycle and I would guess a few old trucks.
I thought it was worth a check.
  #39 (permalink)
Old 11-05-2009, 11:28 AM
daveengelson's Avatar
daveengelson daveengelson is offline
daveengelson is gaining momentum as a positive member of FTE. daveengelson is gaining momentum as a positive member of FTE.
IMHO it's the nature of the beast starting a 390 on a cold winter morning, finally went with Electronic Ign., Duraspark ll, and now no longer an issue.
__________________
'problem with engaging in useless activity is never knowing when your done'
Never engage in a battle of wits half armed!
65F100, 302ci, T18, swb, flareside,front disc. PS, Duraspark Ign.
65F100, 390ci, 3sp.OD, lwb, styleside, front disc., Duraspark Ign.
dave
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
