Quote:
Originally Posted by ddabb
I need to replace my 4.6 in my 2003 expy. Will a 2002 fit? Or will a 2003 5.4 fit?
ALL 4.6L iron blocks are the same externally.
The differences between Romeo and Windsor are minor-the only one that'll cause you problems is the number of flexplate to crankshaft bolts. Windsors use 8,and the Romeos use 6. This is really a non-issue,all 4.6L's are internally balanced,so all you need is a flexplate with the correct number of crankshaft bolt holes.If you end up with a different year model,I'd suggest using the top end (induction,etc) from your original engine to help prevent any hassles with senor locations being slightly different,and problems with the harness.
A 5.4L would fit fine-you'll just have to alter the exhaust and the PCM will need a custom tune to be perfect. It'll run off of the 4.6L PCM, but it won't be optimal.
JL
