Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-22-2009, 01:05 AM
OldSkewl 79 OldSkewl 79 is offline
OldSkewl 79 is starting off with a positive reputation.
Timing setting question
Hi guys. Im fairly new to engine building. I have 1 previous build on a 300 straight six with some performance upgrades. It was 5 years ago and pulls like a tank still. 6500lb class at fairs.
Now Im rebuilding a 302 that is .040 over, stock 2bbl, tranny etc.
My questions is this. I have purchased an after market cam 290/300 adv. duration .472/496 lift 112 degree lobe to be specific - - do I need to do anything special to the timing? what should I set it at for normal driving.
My 300 I just set it to what Im doing with it at the time. be it pulling the sled, hauling rock or ?? or playing in mud.. It could always be better but the truck has a life of beating around nothing like my 302 . The 302 is to be driving daily up and down highways.
Or should I start out at about 8-10 degrees like stock and just adjust as needed?
any help would be appreciated.
Thanks
C
__________________
If you give your work away for peanuts expect to attract more than your fair share of squirrels!!
______________________________________
79 F100 Short Bed, Step Side 2wd - 302, C4, AC, Tilt. -
80 f250 300 sixer, 4bbl, headders, 268 cam kit, 33 pitbulls, dana 70 locker rear, 4spd.
  #2 (permalink)
Old 10-22-2009, 07:47 AM
gfw1985's Avatar
gfw1985 gfw1985 is offline
gfw1985 is starting off with a positive reputation.
You've got it right, 8-10 to get it started. You already know more advance as long as it isn't pinging for performance, less for economy. With aftermarket cam I'd tune it with a vacuum gauge and just use the timing light for a referance.
__________________
76 Bronco Explorer 289 Hi-Po
66 U14 Half Cab Bronco frame off in progress
  #3 (permalink)
Old 10-25-2009, 05:47 PM
Ok.. thanks I will try to get my hands on a vacuum gauge. Ok now my question is what am I to look for with the vacuum gauge? I have never used one.
Thanks
__________________
  #4 (permalink)
Old 10-25-2009, 05:56 PM
gfw1985's Avatar
Time for max manifold vacuum, then back off 1-2 hg.
__________________
Tags
289 , 300 , 302 , 79 , adjust , advance , bronco , engine , ford , hipo , set , steps , straight , timing , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
