Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
brake parts needed
Old 10-21-2009, 09:51 PM
370dumpman's Avatar
370dumpman
370dumpman is offline
Unhappy brake parts needed
I have a 1978 F700, eaton rear end. I am having trouble finding the rubber brake line that goes from the left frame(over diff) to the top of the diff.I cannot find any stores who can get this part. Any suggestions would be nice. Thanks Joe
Old 10-22-2009, 12:24 AM
grm61's Avatar
grm61
grm61 is offline
Try a industrial hydraulic hose and fittings store, many of them can make rubber brake hoses.
Greg
Old 10-22-2009, 10:11 AM
1ARyan's Avatar
1ARyan
1ARyan is offline
FTE Sponsor
There's a company called Inline Tube that carries rubber brake hoses. The have premade hoses (GM and Mopar only), but they can also provides custom hoses. They're a good company to deal with, and they should be able to get you what you need.
Old 10-23-2009, 04:46 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
I cannot find any stores who can get this part. Did you try a Ford Dealer? These hoses are usually a Ford Dealer part only.
Welcome to FTE
1973/79 F600/750 2WD: There are two different brake systems and hoses listed in the parts catalog.
ILLUSTRATED here: 1973/79 Ford Heavy Truck Parts Catalog / Section 22, Page 1.
D5TZ2282J .. Rear Brake Rubber Hose-Use with Single Hydraulic Brakes.
Connector on Axle to Frame Brake Hose.
Available from Ford.
MSRP: $60.00 // FTE sponsor Y2KFORDPARTS.COM price: $43.20.
D5TZ2282J .. Rear Brake Rubber Hose-Use with Split Hydraulic Brakes.
Connector on Axle to Frame Brake Hose - FRONT port of connector.
Available from Ford...see above.
D5TZ2282K .. Rear Brake Rubber Hose-Use with Split Hydraulic Brakes / Obsolete
Connector on Axle to Frame Brake Hose - REAR port of connector.
KINSEL L/M in Beaumont TX has THREE = 800-543-4959.
KOVATCH FORD in Nesquehoning PA has THREE = 570-669-5118.
GREEN SALES CO. in Cincinnati OH has TEN = 800-543-4959.
If these hoses seem in-correct, or you are confused which is which (by my description), you need to see the parts catalog illustration.
Contact GREEN SALES CO. (greensalescompany.com) and ask them to FAX or email you a copy of the above parts catalog illustration.
This is a free service. Green Sales is the world's largest Ford obsolete parts vendor.
I cannot scan and post this jazz, because my parts catalog is on microfiche.
Old 10-24-2009, 12:52 AM
Broncoholic1's Avatar
Broncoholic1
Broncoholic1 is offline
Sweet, He said Microfishe'
Joe_C
05-11-2010 11:20 AM
horsez2go
03-17-2009 09:05 PM
LRanger97
1983 - 2012 Ranger & B-Series
12-31-2007 08:40 AM
JOE-M
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
03-20-2006 11:15 PM
Joe51f1
04-21-2003 05:00 PM
Quick Reply: brake parts needed
