Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
  #1 (permalink)
Old 10-21-2009, 09:49 PM
superrangerman2002 superrangerman2002 is offline
Garage is empty, add now
superrangerman2002 is gaining momentum as a positive member of FTE.
Accel COP, anyone using?
Hey all,
Was wondering if anyone has any experince with the ACCEL COP's?
Were they worth it?
http://www.accel-ignition.com/Produc...2-VALVE%20COIL
__________________
'10 F150 5.4L Supercrew FX4 with all of the goodies.
  #2 (permalink)
Old 10-22-2009, 06:40 AM
chaser1602 chaser1602 is offline
chaser1602 is starting off with a positive reputation.
Stolen from a post I found by using the search :cop
I had purchased a new set of COPs from Performance Distributors, a site sponsor some time ago. Their product called Sultans of Spark is a aftermarket high output COP. I decided to take the time to install them and fix the problem for good.
Probly not perty yella ones but everyone who uses um luv em
  #3 (permalink)
Old 10-22-2009, 11:56 PM
jdhudall jdhudall is offline
2001 Ford F-150
jdhudall is starting off with a positive reputation.
I got sick of spending $80-90 each for the stock ones every six months so I replaced all 8 with the accel performance ones at $25 each it was a great investment runs better more power better cold starts and it has been 2 years and 25,000 miles and no problems yet!
  #4 (permalink)
Old 10-23-2009, 01:34 PM
papajoemrt's Avatar
papajoemrt papajoemrt is offline
papajoemrt is starting off with a positive reputation.
I haven't used them, but maybe if I have to do them next time I will look into the set of them to try them.
People on here will say go with motorcraft because these motors are very sensitive with the ignition. look up what happens when people use other brand of spark plugs. You might get a code for running these but who knows for sure.
__________________
2002 F-150 Screw
Kenwood DDX512, Pioneer Doors, Image Dynamic Subs
Dumped Flowmaster Super 40
Trans-Go Shift Kit
Gotts Intake Mod
  #5 (permalink)
Old 10-23-2009, 01:42 PM
JJ98 JJ98 is offline
1998 Ford F-150
JJ98 is starting off with a positive reputation.
I replaced both of mine on my 98 at 256000 on a tired engine it mad it start better
and mpg inproved 1or2 no codes or blown plugs
  #6 (permalink)
Old 10-24-2009, 05:27 AM
phil6608's Avatar
phil6608 phil6608 is offline
phil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant future
There is no reason to replace the stock COPs unless you are having a miss problem.
The stock motorcraft Are the best!
Iv been around for a wile and only here bad things about the accel COPs. Every now and then you will here someone that actually got them to work on there truck but 95% of the time it's all BAD!
If you do have a problem ,,most people have had great luck with this COP. It's made by the same company that makes the stock ones at a faction of the price.
NEW IGNITION COILS 97-06 FORD F150 F-150 V8 DG508 (8) :eBay Motors (item 110418765722 end time Oct-26-09 09:59:22 PDT)
Oh,,and by the way.
I'm making over 650rwhp with the stock COPs!
__________________
( Phil )2003 SuperCrew: JLP Built Lightning block/Stage 3 heads and cams.
L-conversion/Kenne Bell upgrade blower at 16PSI/BTS,4R100 tranny/100 shot nitrous.
594HP/620TQ Without the Nitrous 1.68 60' time/11.76 @ 116.17 with the 100 shot.
Join the the Delaware Chapter, HERE
  #7 (permalink)
Old 10-24-2009, 01:15 PM
2001 Ford F-150
Well I have had nothing but trouble with motorcraft I have replaced one 7 times in 5 years and have had no luck with the stock ones! I replaced # 7 last time with the stock replacement and it only lasted 5000 miles that is when I switched to accel performance ones no-codes no problems 25,000 miles later and running better than ever before and I did gain mpg and a little better throttle response faster starts in the cold Minnesota winters! So don't be scared you can replace all eight for the cost of 2 motorcraft ones which is a smart buy if you ask me but that is only my opinion!
Oh,,and by the way.
Tags
02, 1999, 9706, accel, coils, cop, cops, costs, dg508, f150, ford, ignition, motorcraft, performance, reviews, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
