Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-21-2009, 10:41 PM
mudslinging79 mudslinging79 is offline
mudslinging79 is starting off with a positive reputation.
small block v-8
what small block v-8s have people dropped in the b/2, other than the 302?
  #2 (permalink)
Old 10-21-2009, 11:34 PM
BIICrawler BIICrawler is offline
BIICrawler is starting off with a positive reputation.
289, 302, 351W, 460(I think this one was a fullsize frame with a ranger body on it), 4.6(was in a ranger), chevy 305 and 350
Not all small blocks or Fords, but those are the V8s I've seen in BIIs and Rangers. The off road club I am in has 2 BIIS with 302, one with a chevy 305, and a Ranger on a fullsize frame with a built 514.
  #3 (permalink)
Old 10-22-2009, 11:26 PM
was looking at possably the 289, am wondering what modifications need to be made for clearance. thinking carbureted model, and having to make motor mounts
  #4 (permalink)
Old 10-23-2009, 04:43 AM
It's the same as a 302. You have to hammer on the firewalll some, how much depends on bodyl ift and what trans you use. You have to clearance the A/C heater box for the passenger side head, again how much depends on body lift.
You have few options on motor mounts. You can spend a lot on swap mounts, or use fox body Mustang convertible mounts. Or you can make some metal plates and reuse your existing mounts. I am using solid mustang motor mounts.
__________________
www.damnlocals4x4.com
  #5 (permalink)
Old 10-23-2009, 11:33 AM
country0001's Avatar
country0001 country0001 is offline
country0001 is starting off with a positive reputation.
I'm saying screw the V-8 option and going with a 4.0 swap into my BII. Its a plug and play option on the 90 model and there are plenty of part for them. I've had many V-8's and I'm still impressed with the way a 4.0 runs.
__________________
92 F-150 Ext Cab 5.8L
200,000 miles
90 BroncoII 2.9L 5speed
94 Ranger 4.0L
  #6 (permalink)
Old 10-23-2009, 12:23 PM
BRay09's Avatar
BRay09 BRay09 is offline
BRay09 is starting off with a positive reputation.
Quote:
Does building a V6 4.0 motor have the same basiccs as a V8? I just got done building my 351w for my F250 and now i was thinking of building a more powerful motor for my stranger. I seen on jegs they do have cams, lifters, rockers, headers, programmers and what not, i just dont know if itd be as easy as a V8. What are your plans and how much TQ/HP are you expecting to see?
__________________
Guzzy
1989 F250 Custom
33" TruXus Mud-terrains
7 mpg city/highway/with plow/without plow/muddin/2000 lbs in bed
In progress: 75 351w with crane 444232 cam, 1.7 rockers in GT40 heads and Flowtech LTs
  #7 (permalink)
Old 10-23-2009, 03:41 PM
As for right now, I'm just going stock. For what I need the 4.0 will be enuff. My BII w the 2.9 pulled a 16' trailer w a tractor on it, and its pretty spunky when I want it to be. The 4.0 in my ranger is pretty stout too. Iwill def go w headers and a better exhaust but as for the other stuff, I don't need it. I like to play in the mud, I'm not doing anything too extreme.
__________________
200,000 miles
94 Ranger 4.0L
  #8 (permalink)
Old 10-23-2009, 05:17 PM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 is gaining momentum as a positive member of FTE.
I wanted to stuff the BIG six 300 in my B2, but that engine is just tooo long to fit with out major hammer time on the firewall. The 4.0 will be the best swap, everything fits properly with no fabing of mounts. Just have to get the wireing for the 4.0 swapped over into the B2
Maybe in the future the 300 I6 might find a way into it... I have a 93 explorer which is almost the same as my Bronco2 to experment on.....
__________________
89 F250 2x4 302/AOD 4.10 gears ,now on road.
89 Bronco2 with dead A4LD again
84 F250 4x4 300/np435 3.55 gears. The BLUE MULE shut down due to cab cancer(looking for good cab)
95 E350 bus conversion 460/E4od 4.10 the new toy!
85 Plymouth Caravelle 2.5L someday to get the hairdryer treatment(turbo)
93 explorer now just a woods buggy
  #9 (permalink)
Old 10-24-2009, 10:02 AM
Especially w the 89 and 90 BII's the 4.0 is a relatively easy swap . Just find a ranger or explorer w the engine and tranny combo and steal the harness and computer, and ur good to go. There are a few issues for the 89 over the 90 because the 4.0 wasn't available till 90. Its rumored that the 4.0 was an option in 90 but no proof of one actually in it from the factory
__________________
200,000 miles
94 Ranger 4.0L
  #10 (permalink)
Old 10-25-2009, 05:41 PM
Old93junk's Avatar
Old93junk Old93junk is offline
Old and mean
1993 Ford F-250
Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold
Putting the 302 in a 1st gen. Ranger or B2 is easy.............I have done 3 of them in 10 years..........Real straight forward no BS swap, almost as if Ford may have considered it at some point in the engineering phase.
__________________
FORCE IT!,IF IT BREAKS IT NEEDED REPLACED ANYWAY!
IF IT CANT BE FIXED WITH A HAMMER, ITS A ELECTRICAL PROBLEM!
Still bitterly clinging to guns and religion.
Dave
Oregon Assistant Chapter Leader: To join the Oregon Chapter, click HERE
  #11 (permalink)
Old 10-25-2009, 08:36 PM
i was looking for a small v/8 that wouldnt require a lift kit or other real mods for my 87 other than motor mounts, body and suspension is stock cept for explorer springs in the back.
  #12 (permalink)
Old 10-25-2009, 10:02 PM
Old93junk's Avatar
Old and mean
1993 Ford F-250
Quote:
See my above post ........NO suspension mods are required to fit the 302.........I have put a 315hp 302 in a former 4cyl. 2wd short bed Ranger (changing to a c6 and a 8.8 of course).
All you need in a B2 is:
motor mounts
remote oil filter
rad. from a Explorer
Your choice of trans to back up the 302( no trans offered stock with a B2 will withstand the 302 for long)......Possibly shortening or adding to drive shaft depending on trans used.
If driven like a adult the 7.5 rear and the Dana 35 front, will hold up.
Exhaust work
Advise from folks here on wiring.
WARNING:..............A B2 with a 302 is a wild ride, and will KILL you!
Drive conservatively!
__________________
Dave
  #13 (permalink)
Old 10-25-2009, 11:26 PM
if i do this, it will be straight carbureted, screw the electrinoc fuel and ignition, old school all the way. am just looking for a little more mid to high end oomph going down the freeway and haulin a trailer. though what about the stock transfer case, or is that not up to a 302?
  #14 (permalink)
Old 10-25-2009, 11:33 PM
Old93junk's Avatar
Old and mean
1993 Ford F-250
Some folks have had luck with the stock trans. case but most simply transplant a F-150/Bronco transmission and transfer case, its much stronger and custom trans mounts are available from several sources. EFI , computer, all can be trashed out if going old school.
__________________
Dave
  #15 (permalink)
Old 10-25-2009, 11:55 PM
My 84 BII came with the C5 automatic. It is still in there with a V8 bell housing and V8 C4 valve body. Along with the stock transfer case. And I am not to easy on it with 38" tires. And I have no body lift. The biggest problem I have had is motor and trans mounts. I have broken the original trans mount, f150 trans mount, oe style mustang motor mounts, poly motor mounts. I now have solid motor mounts with a poly trans mount and they seem to be holding up good. The C5 is the only stock BII transmission that I would consider running behind a V8.
If you run a F150 transfer case some, like the BW1356, won't fit without notching the frame.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
