1997 Odometer not working.... - Ford Truck Enthusiasts Forums
Old 10-21-2009, 08:41 PM
Futuresweets-10's Avatar
Futuresweets-10 Futuresweets-10 is offline
Futuresweets-10 is gaining momentum as a positive member of FTE.
Hello all, this is my first post in the f-150 section as I drive a 250. I bought a 97 f-150 today that needs a little work. The mileage is 96,365 and I noticed that after driving it back to the job site the mileage hadnt changed at all. The speedometer and all other gauges work. Odo and trip odo are the only ones that dont work. Can anyone point me in the right direction on finding the problem? What can cause this? How easy of a fix will this be? Thanks in advance guys
Old 10-21-2009, 10:27 PM
Hybris's Avatar
Hybris Hybris is offline
Hybris is gaining momentum as a positive member of FTE.Hybris is gaining momentum as a positive member of FTE.
Just to clarify the mileage itself is not changing or its not showing up every time you start the truck.
Old 10-21-2009, 11:08 PM
Quote:
It would have to show up considering no 97's have digital odometers, or am I understanding the question wrong. The mileage is not changing at all. The dials dont move.
Old 10-21-2009, 11:18 PM
n3up's Avatar
n3up n3up is offline
n3up is starting off with a positive reputation.
Could possibly be stripped gears in the Odo...
Try fiddling with the trip odo reset.
My T-Bird did the same thing once, and it was just jammed.
Fiddling with the trip reset freed it up.
The good thing is if the odo gears are stripped, you can swap the speedo on a 97 with out much hassle since they don't have PATS....
Old 10-22-2009, 12:05 AM
Just got in the house from messing with it.... took the entire cluster out and disassembled it. The drive gear on the motor that moves the odometer has fallen apart. Does anyone know if I can get the motor as a part or if I will have to buy an entire cluster?
Old 10-22-2009, 07:03 AM
l-m tech l-m tech is offline
l-m tech is gaining momentum as a positive member of FTE.
i use southern electronics.give them a call.1-800-446-2880
08 f250 abs light, check brakes fault, speedo dont work!!!!!!!!!!! sonicsaleen 1999 to 2016 Super Duty 31 05-30-2016 12:36 AM
91 F150 odo/speedo not working alvirostko 1987 - 1996 F150 & Larger F-Series Trucks 10 12-08-2015 04:29 PM
New Truck! ng19delta 1987 - 1996 F150 & Larger F-Series Trucks 8 09-10-2015 03:17 PM
1994 F150, digital odo. doesn't light up? IDIDieselJohn 1987 - 1996 F150 & Larger F-Series Trucks 10 06-11-2012 08:12 AM
Odometer works but speedo doesn't...? thordehr 1999 - 2003 7.3L Power Stroke Diesel 19 11-23-2010 12:09 AM
Tags
1997, 1999, 97, 99, f150, f250, fix, ford, gauges, gears, odometer, stopped, truck, working, workings
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
