Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-21-2009, 06:31 PM
MrRogers's Avatar
MrRogers MrRogers is offline
MrRogers is starting off with a positive reputation.
E40D shifting rough in 1 gear
Howdy fellas,
This one is a little bit queer. My tranny works ok (a little hesitation or some rough downshifting every now and then) but from 3-4 it's really bad. So bad I've replaced front and rear U-joints twice in 3 years. If I accelerate to 35 mph (1500 rpm) and let off the gas it shifts really rough and you can hear a clunk. But, if i accelerate through to 47 mph (~2100 rpm) it'll shift smoother. Just so I'm explaining this clearly: It shifts really rough from 1500 to 2100 rpms. All the other gears are as healthy as can be expected from a tranny w/ 260k on it. I was thinking about replacing the MLPS but wanted to get some opinions.
Thanks,
Josh
__________________
Black 1990 F150 302 2wd
  #2 (permalink)
Old 10-21-2009, 06:32 PM
MrRogers's Avatar
Forgot to mention: No codes thrown
__________________
  #3 (permalink)
Old 10-21-2009, 10:17 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Former Ford AutoTrans Eng
Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold
It could be a damaged trans or motor mount. It is almost certainly not the MLPS. That would cause no shifts or harsh shifts at any speed.
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
  #4 (permalink)
Old 10-21-2009, 11:51 PM
MrRogers's Avatar
yeah i was afraid of that...oh well. Guess I'll spend the money and get it looked at
__________________
  #5 (permalink)
Old 10-27-2009, 09:35 PM
archangel archangel is offline
archangel is new and has a neutral reputation at this point.
Also, internal wear between the forward drum and the center support can cause a real harsh 1-2 shift.
But the F.I.P.L is the main cause of most shifting issues.
I would not spend a dime having anything checked out (other than the fluid level as you can do it yourself) unless I replaced the F.I.P.L. first.
__________________
Gray 1991 F250 standard cab, 7.3, E4OD, 3.55:1, stock wheels and tires.
Verified 19 mpg city taking off slow as hell the shutting down at red lights, and with the radiator grill blocked flush, no bed cover, "drag shoot" mirrors on I get 24 mpg at 50 to 55 mph on the freeway empty!
However, with a bed cover, no mirrors and Hydroxy
  #6 (permalink)
Old 10-28-2009, 11:58 PM
MrRogers's Avatar
Hmmm....I'm not knowledgeable about transmissions at all so I have no idea what that is. Any good links or tips. Thanks
__________________
Tags
1995 , automatic , e40d , e4od , f150 , f250 , ford , gear , harsh , mlps , rough , shift , shifting , shifts , transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
