Need Some Guages.... - Ford Truck Enthusiasts Forums
Old 10-21-2009, 04:57 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
So the next mod on my list is guages...
What do you have?
Where did you get them?
How do you like them?
How much should I expect to pay?
Old 10-21-2009, 05:00 PM
HKusp's Avatar
HKusp HKusp is offline
HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.
Get with Clay at Riff Raff performance. He has some very good pricing on Isspro's(which I have had 2 sets of) they are nice. A big plus is they are made in the USA (Washington State I believe).
If you are going with the standard 3 gauge, Pyro,boost and tranny temp somewhere in the $300--$325 range is about right.
Old 10-21-2009, 05:57 PM
WA.Ranger's Avatar
WA.Ranger WA.Ranger is offline
WA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to all
ISSPRO's as Jason said. I have the EV2's and love them. LED Backlit is awesome. If you want to go up from there, get the Performax. As was stated, give O' Clayton Bigsby a call at Riffraff, he'll steer you straight. Made in Oregon, USA!
Old 10-21-2009, 06:15 PM
duck fan's Avatar
duck fan duck fan is offline
Because racetruck
duck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant future
Yup ISSPRO is in Portland, OR
Old 10-21-2009, 06:19 PM
HKusp's Avatar
Quote:
Oregon, Washington, it's all Big Foot country.
Old 10-21-2009, 06:32 PM
figurhead's Avatar
figurhead figurhead is offline
figurhead is starting off with a positive reputation.
Not to break the ISSPro bubble (they are very good gauges), but I went with Autometer Z-Series (black with white numbers), with seperately purchased Green LED backlights. They usually run $45-$70 each (pyro is a little more) & $10 more for LEDs. Summitracing or ebay or wherever.
I have installed: Voltmeter, Ammeter, Pyrometer, Boost. (pics below)
Installing this weekend: Trans Temp, Oil Temp, H20 Temp, Fuel Pressure, Oil Pressure, Diff Temp.
Overkill, maybe for some. But I love to see that everything is working, it's much better than the dummy light. I went with analog gauges for most of them for realtime feedback (some gauges only come digital).
There are pro's & con's for every maker of gauges. The battle is stupid. Some are definitely made a little better, others are a little cheaper, but they all still do the job, or fit a particular budget. What you like and can afford is the key.
The ISSPro EV2 are similar to the Autometer Z-Series. Cartmanea has a nice setup with the EV2's:
http://www.ford-trucks.com/forums/83...ts-o-pics.html
I think my setup is starting off pretty nice, fashioned after/copied from his setup. I am still not done; I am in the middle of the process with two more triple pods to install.
<img src="http://www.emctempest.com/f350/DSC08352-small.jpg" /IMG>
<img src="http://www.emctempest.com/f350/DSC02162-large.jpg" /IMG>
<img src="http://www.emctempest.com/f350/DSC02163-large.jpg" /IMG>
Old 10-21-2009, 06:45 PM
jeff7825's Avatar
jeff7825 jeff7825 is offline
jeff7825 has a good reputation on FTE.jeff7825 has a good reputation on FTE.jeff7825 has a good reputation on FTE.
I like my Dipricols. Here is what they look like......
Those are fuel pressure and HPOP gauges. I also have pyro, boost, and trans. temp on the pillar.
Old 10-21-2009, 06:54 PM
figurhead's Avatar
jeff7825, Nice setup. I have that triple pod (to be installed shortly) on the right knee with Trans Temp, Oil P (?), Diff Temp. I forgot about the HPOP. What pressure gauge is that for your HPOP (Oil Pressure guage?) and where did you place the sender?
Old 10-21-2009, 07:15 PM
big poppa's Avatar
big poppa big poppa is offline
big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.
Figurhead, I must say, those gauges installed below you instrument cluster are very nicely done, superb job. TD, I got my complete gauge kit, boost, trans, pyro from Dieselmanor, nice kit and everything you need for the install, directions were right on, good if you never installed gauges before, like most of us before we got them. I also got these before Clay was in business so I would give Clay a shout at Riffraff diesel, he's got great customer service and he's always been there before and after the sale, great fella to deal with.
Old 10-21-2009, 07:39 PM
bigb56's Avatar
bigb56 bigb56 is online now
bigb56 has a great reputation on FTE.bigb56 has a great reputation on FTE.bigb56 has a great reputation on FTE.bigb56 has a great reputation on FTE.bigb56 has a great reputation on FTE.bigb56 has a great reputation on FTE.
figurhead, is that the instument bezel mount kit or did you cut them right into the dash??
Old 10-21-2009, 07:41 PM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
PREMIUM SPONSOR
Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.
Quote:
The HPOP gauge is a specific gauge only for that function since it read up to 4,000psi. I am only aware of Isspro and Dipricol making one at this time.
Your gauge setup looks nice man. To bad you didn't start with the Performax series before you turned it into the Space Shuttle cockpit, LOL. Starting to look like CSIPSD
Old 10-21-2009, 08:02 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
I don't know how Dipricol does it, but my Performax HPOP gauge came with a plug-and-play connector for the ICP sensor. The gauge is electronic. To run the Performax gauges you need the ISSPRO ESP (Electronic Signal Processor).
Old 10-21-2009, 08:13 PM
figurhead's Avatar
bigb56, I cut the holes with a 2" tile drill bit/hole saw. It melted the plastic bezel perfectly for the 2 1/16 gauges. I just measured the center, marked it and drilled it, using a blade to clean the edges that were melted. The right side is perfect for whatever gauge with nothing behind the bezel but good access to the radio power wires (for keyed gauge power and dimmer power).
The left side has a thicker/lighter colored plastic "framework" behind that I melted perfectly by heating a hack saw blade with a small butane torch, after drilling and removing the bezel. The link above to cartmanea's installation shows it pretty well (he used a dremel to make gauge room).
I chose the Ammeter for the left side since it is the shortest distance to the alternator. It is cool to see it pump out 30-60 amps. At least I know that it is working. I ran 8 gauge cable (75A) which is the same size as the wire coming off the alternator.
RiffRaff, There were too many options and using so many gauges, the Autometers seemed right. I can't second-guess now. Anyway, I'll have to see about the HPOP gauge. That seems like a pretty important one.
Would the HPOP be more important or the same importance as oil pressure, to be monitoring? And where would the oil pressure gauge go to? I'm thinking that Oil Temp will be drilled & welded into the oil pan on my next oil change. Any help?
I just checked out the IISPro Performax and they are very nice. Hadn't checked them out so closely before.
Old 10-21-2009, 08:59 PM
bigb56's Avatar
It's a very nice job
Old 10-21-2009, 09:59 PM
frdf250's Avatar
frdf250 frdf250 is offline
frdf250 has a very good reputation on FTE.frdf250 has a very good reputation on FTE.frdf250 has a very good reputation on FTE.frdf250 has a very good reputation on FTE.
If you dont want to spend alot and and want decent gauges go to google "glow shift pro" ive gotten all my gauges there and have never paid over 160 that was for boost 2000f exaust and tranny. it comes with probes and hoses and stuff. mounts real nice.
alt guage problems choptop49ford 1973 - 1979 F-100 & Larger F-Series Trucks 21 11-22-2012 09:24 AM
EGT and Boost guage install Q's LiftdFord 1994.5 - 1997 7.3L Power Stroke Diesel 4 01-05-2010 12:27 PM
Need advice installing aftermarket guages 97Handshaker 1997 - 2003 F150 6 07-02-2008 08:13 AM
Instrument panel is fogged 73f100shorty 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-08-2007 03:48 PM
The Great Guage Debate priv8pilot 1999 - 2003 7.3L Power Stroke Diesel 14 10-31-2006 10:28 AM
Tags
73, bouncing, double, gauge, guages, isspro, location, oil, optix, powerstroke, pressure, processor, pyro, sale, sender, sided, signal, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
