Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-21-2009, 04:21 PM
Copedawg's Avatar
Copedawg Copedawg is offline
Copedawg is starting off with a positive reputation.
Front tow hooks
I know I've seen it before but I can't find it.
I am looking in to putting front hooks on. I was looking at a 05? F150 hooks that bolt straing on the bottom of frame. I looked at my truck and the springs are there so that won't work as a "bolt on and go". Any other ideas?
__________________
Ian pronounced E-N just like the letters sound. 97 F350 7.3L Auto 4WD Crew Cab 195K. MODS: HOOOOGA! horn, PO MAN's air intake, Service/Utility bed, 3" DP, Testing that Cat, FPR shim (whoknows PSI), 140v IDM, 2 10K pots. US ARMY OAS, OJE-IFOR, SFOR,2,5, OJG-KFOR, OIF, OEF.
To ALL that have served, THANK YOU!
  #2 (permalink)
Old 10-22-2009, 12:08 AM
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch is starting off with a positive reputation.
can you bolt to the outside of the frame rail???? or maybe build something that would bolt to the bumper mounts...
__________________
DEATH ROW DIESEL INMATE # 7-- TRAVIS
1995 F-250 PSD- Tony's tunes, CPR fuel system, 120v IDM, T.E 17* HPOP, DIY stage 2's, val-air full ceramic clutch, ISSPRO's, 3" dp-5" stacks, IC, ccv mod, 6637.... DYNO'D 352hp/731tq w/ stage 1's........... '94 F150 SC SB 4x4 5 speed(PROJECT!)
  #3 (permalink)
Old 10-22-2009, 05:23 AM
Copedawg's Avatar
I looked around and I didn't reallt see anywhere to do that. I don't know what the hooks from the SuperDuty look like but maybe that it the 1 I need?
__________________
  #4 (permalink)
Old 10-22-2009, 07:33 AM
rat49f6's Avatar
rat49f6 rat49f6 is online now
1999 Ford F-250
My Garage
rat49f6 is gaining momentum as a positive member of FTE. rat49f6 is gaining momentum as a positive member of FTE.
Sd tow hooks go in the front of the frame rails
__________________
JIM
early 99 F250 super duty ...ext cab...xlt... 7.3 powerstroke...6 speed...'08 8ft bed...
6637 mod ...factory muffler delete...TS Performance 3 position 75/100/140+ extreme chip...6.0 i/c w/ riff raff boots
1949 Ford f6... flathead v8... 4 speed crash box...
10" frame drop... 6" body drop ...work in progress
  #5 (permalink)
Old 10-22-2009, 08:45 AM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
1995 Ford F-350
My Garage
Brown Falcon is starting off with a positive reputation.
Don't bolt anything to the stock bumper mounts... they are crap! Bolt to the frame or forget about it.
__________________
Brownie, Ooh-Rah! USMC Member of the NRA!
'95 F350 CC 4x2 - SRW Swap, E40D, PHP 6 Pos. Chip, 6637 mod, 3" D.P., Lost Kitty, 140v IDM, HPX Mod, FPR Shim (65 psi), T.C. switch, 3.55 gears
'88 F350 CC 4x4 - lots of dents, faded paint, old 7.3 IDI in pieces
  #6 (permalink)
Old 10-22-2009, 08:33 PM
rodneywar's Avatar
rodneywar rodneywar is offline
rodneywar is starting off with a positive reputation.
x2 on bolting them to the frame rails my bumper brackets are bent outta shape from the plow mount that was on it
__________________
Ronnie Warfield
1995 F 250 Turbo diesel reg cab 2wd
6637 mod, 3 inch dp, lost kitty, GPR mod, 120v idm, 2500 watt inverter
Maryland Chapter member
  #7 (permalink)
Old 10-23-2009, 01:27 AM
ok so do what i'm going to do and weld in some supports on y'alls bumper mounts!!!!!!! LoL. take some 3/8" flat plate steel and cut it the height of the mounts and long enough to go a 45* angle to meet the frame. weld it in and your done. for a little added strength build another piece from the same steel to go from the bottom of the mounts cut the angle out so it stays with the other support and weld it up on all sides including to your other suppot. do that again on top also. mounts wont move then will they??? LoL. or you can just bolt your hooks to the frame and still bend the mounts when you hit your next deer or whatever you may hit... haha. i plan to do this eventually when i park my truck for a bit. i'm doing it to the F150 first so i can get it down then it will be easy on the stroke
__________________
  #8 (permalink)
Old 10-23-2009, 03:06 AM
Oversize's Avatar
Oversize Oversize is offline
1996 Ford F-250
Oversize is gaining momentum as a positive member of FTE.
You can do it two different ways with relative ease.
1. Bolt the hook to a piece of 3/8" thick angle iron and bolt that the side of the fram rail through the front of the frame tube.
2. Cut 2 small notchs in the bottom of your stock bumper at the frame rails to go around the hooks and bolt them to the frame directly.
__________________
96 F-250 HD, SC, LB, 7.3 DI Diesel, 5 spd, 6" lift, 35" AT's, 3" DP, cat gut, 6" straight pipe, 4.10's, FPR shim, custom intake, Hot pedal, HPX, Pyro, Boost, ...
Professional driver, Former CAT and Industrial Mech, P/T race engineer.
  #9 (permalink)
Old 10-23-2009, 03:45 PM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
1996 Ford F-250
RÖENTGEEP has a good reputation on FTE. RÖENTGEEP has a good reputation on FTE.
Check this:
http://www.thedieselstop.com/contents/getitems.php3?DIY%20Tow%20Hooks
http://rides.webshots.com/album/555528764dEiWTo
__________________
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 143K.
DIY intake and exhaust brake. DP 3-3.5" ceramic coated; HPX; GPR switch; Isspro gauges; shim FPR; tranny cooler; CCV mod; 4" stainless Magnaflow; SS 5" tip; no cat; RacerX VB; TW 6p chip; 203*.
«Primum non nosere»
  #10 (permalink)
Old 10-23-2009, 04:50 PM
Copedawg's Avatar
Cool! That is kinda what I am looking for roentgeep. Thanks for the links!
__________________
  #11 (permalink)
Old 10-23-2009, 07:02 PM
RÖENTGEEP's Avatar
FOREIGN GURU
1996 Ford F-250
Wink
Glad to help you.
Any time, you are welcome.
__________________
«Primum non nosere»
  #12 (permalink)
Old 10-23-2009, 07:30 PM
Copedawg's Avatar
I'll show you the final outcome.....I think I can airbrush the duct tape to make it look good. j/k the links are what I was looking for. You are OK I don't care what Neal says lol, just ribben the new chapter prez. Neal, ya know that the new leader buys the beer for all who attends the 1st the GTG. I think they call it a bail out or something. See you in Tn roentgeep! Thanks Neal!
__________________
  #13 (permalink)
Old 10-23-2009, 10:03 PM
1995 Ford F-350
My Garage
What year truck are those tow hooks from in the second link?
__________________
  #14 (permalink)
Old 10-23-2009, 10:15 PM
Copedawg's Avatar
They look like cut SD
__________________
  #15 (permalink)
Old 10-24-2009, 11:10 AM
MagKarl MagKarl is offline
MagKarl is starting off with a positive reputation.
No way would I do it like the first link, but that second link is a great setup. I have seen GM trucks with hooks that look sort of like that, maybe they are GM hooks? I built a new bumper with a 2" reciever in it and an insert with a shackle instead of a hook.
__________________
1995 F350 XLT CC 4WD PSD 5 Speed
2001 Excursion Limited 4x4 V-10
Tags
1990 , 2001 , 2008 , 31310 , bolt , bolts , curt , f150 , f250 , ford , front , hook , hooks , receiver , tow
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
