Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-21-2009, 11:48 AM
poormansrodshop poormansrodshop is offline
poormansrodshop is starting off with a positive reputation.
Exclamation Let's see pics of finished engine bays/under hood
Ok so I am about to start working on my engine bay and thought i would see what you guys have done. So post some pics thanks in advance poorman
  #2 (permalink)
Old 10-22-2009, 12:10 PM
BigPapi's Avatar
BigPapi BigPapi is offline
BigPapi is starting off with a positive reputation.
Yes, it is sad...
But Ive only had it a month or so....
__________________
2004 F250 SD Crew 4x4 6.0 PSD - 4" MagnaFlow
AiRaid CAI - Supah Chips Flashpaq - 285 BFG AT
83 F100 XL 4x2 - 351/302? - C6
What air filter?
  #3 (permalink)
Old 10-22-2009, 02:59 PM
bghnkinf250 bghnkinf250 is offline
1986 Ford F-250
bghnkinf250 is gaining momentum as a positive member of FTE.
BigPapi, what carb do you have on there?
__________________
"A man does what he must - in spite of personal consequences, in spite of obstacles and dangers and pressures - and that is the basis of all human morality."
  #4 (permalink)
Old 10-22-2009, 04:30 PM
van o van o is offline
van o is starting off with a positive reputation.
this is my 460
sorry for the size cant seem to figure out how to make them bigger
  #5 (permalink)
Old 10-22-2009, 04:38 PM
bashby's Avatar
bashby bashby is offline
bashby is gaining momentum as a positive member of FTE.
Here's a couple out of my gallery
__________________
86 F350 2WD Duallie dump. 351W edelbrock cam, carb, d/p intake,C6, D0OE heads. 4.10 gears
  #6 (permalink)
Old 10-22-2009, 08:10 PM
ArdWrknTrk's Avatar
ArdWrknTrk ArdWrknTrk is online now
<--Dog is my Co-pilot
ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold
Before:
After:
__________________
Jim
'87 F-250 4V 460, T19, 4x4, 4.10 sterling 10.25" - Lil' Red
http://i246.photobucket.com/albums/gg117/donjamer/FTE%20Pics/blumax500-1-1.jpgFTE Fraternity of Blue Max
  #7 (permalink)
Old 10-23-2009, 08:22 AM
BigPapi's Avatar
Quote:
I have no idea. I am amazed that it actually works. I have been scouring local boneyards trying to find something to replace it. When they put the 351 in it, they took all the original stuff off and threw it away (I guess) its got an edelbrock 'StreetMaster' intake and the carb is just sitting on it with an adapter. I would like to find a nice 600cfm or so 4 barrel. This one is a 4 barrel, but the secondaries dont work, or it might be the primaries. It took me about an hour or so of adjusting it to get it to idle.
__________________
What air filter?
  #8 (permalink)
Old 10-23-2009, 11:14 AM
1986 Ford F-250
It looks like a Quadrajet, I was justcurious because my Holley works - sort of, and I had been contemplating the swap, but have not found anyone actually running one on a Ford.
__________________
  #9 (permalink)
Old 10-23-2009, 01:09 PM
BigPapi's Avatar
I have had a couple of holleys in the past. The one thing that I like about the quardrajet is that once its setup you dont have to fiddle with it anymore. I have had several and a friends dad is a whiz when it comes to the quadra-bog, he can set it up right. The holleys always needed 'tweaking', well at least the ones I have had. I just want something dependable.
__________________
What air filter?
  #10 (permalink)
Old 10-24-2009, 06:30 AM
ozstang65's Avatar
ozstang65 ozstang65 is offline
ozstang65 is starting off with a positive reputation.
I haven't got any recent pics but here's a couple from earlier in the build. I still have to make the brackets for the air conditioner and hook up the heater hoses. I hope to get it running on gas in the near future so there'll be the regulator and adaptor for the carby to go in also.
  #11 (permalink)
Old 10-24-2009, 10:15 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a good reputation on FTE. ctubutis has a good reputation on FTE.
My truck isn't really anything to brag about and show off but here's what the engine
compartment looks like right now:
  #12 (permalink)
Old 10-26-2009, 10:05 AM
1986F150six 1986F150six is offline
1986F150six is starting off with a positive reputation.
The engine looks very nice! I envy your factory tool box and under hood worklight.
  #13 (permalink)
Old 10-26-2009, 07:41 PM
6fifty_f1fifty's Avatar
6fifty_f1fifty 6fifty_f1fifty is offline
6fifty_f1fifty is starting off with a positive reputation.
Quote:
Originally Posted by BigPapi View Post
Yes, it is sad...
not as sad as mine...
not the latest pic, I have since painted the valve covers and aircleaner blue. I have a lot of work left in this girl to do.
__________________
Robert
--1980 F-150 Custom 302, 4sp OD
--1980 F-100 Ranger 300, 4sp OD
  #14 (permalink)
Old 10-26-2009, 07:47 PM
b-e-a-u-t-i-f-u-l ctubutis,
what intake manifold did you use for that? and is it a 460 or 400, I can't make out the numbers...
  #15 (permalink)
Old 10-26-2009, 11:26 PM
ctubutis's Avatar
Thanks, man
It's a 400, rebuilding it was Summer 2008's project; .040 over, Edelbrock
Performer 400 manifold, Holley Truck Avenger 670 carb, TMI hypereutectic
pistons, mild head porting, Engle high-altitude RV cam, roller timing set,
long-tube headers, true duals, T-18, 4.10 limited slip rear end, I think that's
about it.
Still lots to be done, though; tranny & transfer case need attention, rear pinion
seal leaks, body has about had it (rust).
In time....
Tags
198 , 300 , 302 , barrel , carb , f100 , f150 , ford , golf , holley , hood , mud , pics , runing , truck , underneath
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
