Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 10-27-2009, 03:24 PM
oddshot oddshot is offline
oddshot is starting off with a positive reputation.
Quote:
Originally Posted by ozstang65 View Post
I haven't got any recent pics but here's a couple from earlier in the build.
It must have been in one heckuva wreck to knock the brake master and booster all the way over to the other side of the truck like that!!!
Y'all might be able to get ya' a BIG ol' come along and winch everything back in place.
...nice lookin' under the hood ... too pretty to be a mud truck!
__________________
oddshot
82 Ford F100 302, 4X4, 4Spd
72 MGB-GT 1.8 4 Cyl, Nissan 5 spd, TBI.
72 MGB Roadster 2.8 GM V6
99 Blazer Grocery Getter
99 Mercedes Benz 500 SL Roadster (the wife's car)
  #17 (permalink)
Old 10-27-2009, 07:36 PM
mds47588's Avatar
mds47588 mds47588 is offline
mds47588 is starting off with a positive reputation.
Here is mine. And the first 6 Cyl posted here too. Nothing really exotic to look at, but thankfully I don't [i]have[i] to spend much time in there. I did replace the water pump and alternator. Today's project was replacing the old coolant/washer fluid reservoir jug with the new larger one. I've been slowly "cleaning" up underneath the hood. By that, I mean taping the wire bundles up and placing them inside the split loom tubing. Replaced the valve cover gasket and repainted the valve cover while it was off. Little things make a big difference in time. Most recently, I had replaced the air conditioning condensor, ALL the lines, and the accumilator. A/C is cold inside now!
__________________
'86 F-150 SB/300 CI/4 SP/OD (adding more weeky)
'02 Taurus SES (100K @ 100mph)
'06 Honda Rancher 4WD ES (max modded)
...all kept at a lil house way out in 'da stix...
  #18 (permalink)
Old 10-27-2009, 10:33 PM
beetle beetle is offline
beetle is starting off with a positive reputation.
1985 F250 w/460, original owner 121 K miles.
  #19 (permalink)
Old 10-27-2009, 10:45 PM
M.L.S.C.'s Avatar
M.L.S.C. M.L.S.C. is offline
M.L.S.C. is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by ctubutis View Post
Still lots to be done, though; tranny & transfer case need attention, rear pinion
seal leaks, body has about had it (rust).
In time....
You forgot upgrading the engine fan - that 4-blader is just tiny man, I'm surprised it can even keep up with such a big engine as yours...
__________________
Real trucks rattle! '90 F350 XLT Lariat, reg cab, dually, RWD, 4.10s, factory tow package, and lots of add-on goodies.
Quote:
Originally Posted by fx4wannabe
Some guys like there GF more than their truck. Not me. They don't make these trucks anymore, they make new GF's everyday.
  #20 (permalink)
Old 10-27-2009, 11:05 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a good reputation on FTE. ctubutis has a good reputation on FTE.
Quote:
But, ya know what? That thing seems to suck (quite literally) like there's no
tomorrow!
I replaced the radiator in '08 as part of the engine build process, also added the
clutch fan. When you start it up (with the hood closed) and hold a lit cigarette
within as far as 15" (eyeball measurements) away, it amazes me to see the air
currents getting sucked into the grille! The small fan doesn't seem to be a
problem at all - size doesn't matter.
  #21 (permalink)
Old 10-28-2009, 11:02 PM
LARIAT 85 LARIAT 85 is offline
LARIAT 85 is starting off with a positive reputation.
Looks good, mds47588.
Quote:
Did the newer reservoir jug fit in the same slots as the old jug in your truck? And is it much larger than the older one?
  #22 (permalink)
Old 10-29-2009, 12:07 AM
mds47588's Avatar
Yes and no. I had to modify it slightly to get it to look just right. The "ear" at the front had to be sawed so that it would slide further into the front of the slot in the inside of the fender to where the bolt hole in the other "ear" would line up over the hole. Then, it stuck out a bit from the fender so I had to create some support from the rear. All tht I did was to take a galvanized carriage bolt and insert thru one of the many holes in the inside of the fender and then run a washer/lockwasher down on it. Next step was to cut off the bolt with a cut-off tool to where the new reservoir jug would sit level and then top it off with a vacuum plug.
This took maybe all of 15min to do start to finish at the most.
__________________
  #23 (permalink)
Old 11-03-2009, 03:53 PM
BigPapi's Avatar
BigPapi BigPapi is offline
BigPapi is starting off with a positive reputation.
Quote:
Originally Posted by bashby View Post
Here's a couple out of my gallery
Bashby, Can you pull the breather and all off and take a pic of it? Im trying to figure out where all these vacuum hoses go (gots no idea...).
__________________
2004 F250 SD Crew 4x4 6.0 PSD - 4" MagnaFlow
AiRaid CAI - Supah Chips Flashpaq - 285 BFG AT
83 F100 XL 4x2 - 351/302? - C6
What air filter?
  #24 (permalink)
Old 11-06-2009, 07:48 AM
Blue80's Avatar
Blue80 Blue80 is offline
Blue80 is starting off with a positive reputation.
Here's a different view of the engine compartment. It's coming together. 408 stroker.
  #25 (permalink)
Old 11-06-2009, 08:15 AM
bashby's Avatar
bashby bashby is online now
bashby is gaining momentum as a positive member of FTE.
Bigpapi, I've got an edel;brock carb and intake with only a couple vacuum hoses, will that do you any good?
__________________
86 F350 2WD Duallie dump. 351W edelbrock cam, carb, d/p intake,C6, D0OE heads. 4.10 gears
Tags
198 , 300 , 302 , barrel , carb , f100 , f150 , ford , golf , holley , hood , mud , pics , runing , truck , underneath
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
