Spindle bearing lube/ yellow o-ring question
Leaving on a road trip next week, so I'm doing some PMS to the front axle. I want to grease the front spindle bearings but don't want to replace the $70 yellow o-ring ifm I don't have to.
Can I remove the outer hub without having to replace the O-ring?
You have to pull the whole hub assembly to grease that bearing. If you have esof you probably should replace it. Guzzle has a write up on it: Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
Damaged seals would show up as rust and moisture on the needle bearing area and inside the hub.
Does anyone have any part numbers for the yellow O-ring im trying to find it online and all i can find is this:Dorman Help! 81060 - O-Ring Kit | O'Reilly Auto Parts . Is this o ring for the main hub or for the locking hub itself?
See Bob at Dieselorings.com for what you need.
http://dieselorings.com/index.php?pa...by=DESCRIPTION
Pop
Pop
That's the one behind the auto/manual stock locking hubs. The yellow o ring is behind the main hub assembly.
Here's a link to Bobs maintenance page, and shoul shed some light on it for you.
ok so the ones that are in the kit i put up are just for the locking hubs, does anyone else have any other part numbers for the yellow o rings im trying to do the work tomorrow so i dont have time to order anything on line. Also do i even need to replace the yellow o rings i have manually locking hubs and manually shifter so i dont think i need to worry about vacuum, i think?
